Mad Professor Fire Red Fuzz [traced]
just wanted to give you a heads up. Built this on a Gruntbox PCB using your notes, sounds real good so far. Your conversion instructions (over at BYOC) have R24 left out. Built it without and got no sound (9v has nowhere to go), then looked closely at a pic of your build and you've got a 100R in R24.
Thanks again.
Thanks again.
This is awesome:) I've been gasssing for one of those for a while and i've been playing around with muffs lately. Could I use the madbean MudBunny pcb for this?? would all of the values correspond with the Gruntbox pcb? thanks
Hi.
I cant seem to find the schem's layout's pcbs or vero for this pedal
I remember seeing them before the forum went down
does anybody has any of this? i had already bought all the components when the forum fell
Also Guero 2.0 thats a beautiful paint job you made for yours , I'd like to make a similar one for the sweet honey OD
- GodSaveMetal
I´m too were is the layout or the PCB for the red FUZZ? please post it!! thanks!!dudeduck wrote:Hi.
- GodSaveMetal
Please somebody repost this? please, please!!!!!!!!!
http://www.buildyourownclone.com/board/ ... 0&p=203535
Not quite the schematic, but someone could probably work backwards from there to recreate it. It's a thread from BYOC describing how to build a Fire Red Fuzz on a Gruntbox board. (The Gruntbox was a Big Muff PCB designed by Madbean that was sold on CJ's website for a time.)
Madbean, does the current Mudbunny project use the same base schematic (especially part numbers) as the Gruntbox? Or could you post the Gruntbox schematic here?
- danielzink
- Completed builds: Too many: www.danielzink.com
- Has thanked: 8 times
- Been thanked: 27 times
Found this on my hard drive:
http://www.danielzink.com
MoonWatcher wrote: Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
