paisley drive volume
I built a paisley drive a little while back and although it's a great pedal it wasn't quite loud enough to keep with my other drives and maintain a consistent volume when switching between them. So when compering circuits with my rockbox boiling point which is similar I noticed the paisley had a 100r input resistor and the BP did not , so I decided to experiment and put a jumper instead of the 100r and at the 100r out the output. While I had the circuit open I also doubled the clipping diodes [ which to my understanding allows more clean sound before clipping making it seem louder] . After plugging the pedal back I was happily surprised that there was a measurable volume increase, enough to put the paisley back on my board. My question to those more knowledgeable is will/can this hurt the circuit or any pedals after it? If this is ok it seems to be a worthwhile mod.
- PaisleyDrive_0_1_schematic.png (10.52 KiB) Viewed 1439 times
- hbo
The 100ohm resistor shouldn't affect volume noticeably, but as you've discovered the clipping diodes will. Swapping them out is not a problem; keep them if you like the sound
Cool ,thanks , I've toyed with diodes before but didn't realise it would make this much difference to volume .I'll be keeping it this way now.
- bato001
The 100r resistors are there for filtering. You alter the sound of the pedal a little when you remove them and gain almost no volume as written above already. Looking at the circuit diagram there is a current booster before the output that should have compensated for any volume loss. Make sure the jfet is actually functional.
Thanks , the jfets are ok it just wasn't quite loud enough to match the volume of my other pedals so I have a consistent volume across my board , based on what you said I have put the 100r back in but left the extra diodes in and the volume didn't go down so I am happy .thanks for the helpbato001 wrote:The 100r resistors are there for filtering. You alter the sound of the pedal a little when you remove them and gain almost no volume as written above already. Looking at the circuit diagram there is a current booster before the output that should have compensated for any volume loss. Make sure the jfet is actually functional.
- zedsnotdead
Hi!!
sorry for the necro!
Sorry for my noob question, but wouldn't increasing R15 (feedback resistor) do the trick and increase volume??
- mictester
Yes it would.
- zedsnotdead
Thank you mictester!
I wonder what would be the right R15 so to make this pedal louder, but avoiding signal clipping on that stage...
Is there a way to calculate it? Just an aproximation maybe....?
