no sound, stumped HELP bajaman real tube overdrive
Ang3lus
Been thanked: 14 times
Post by Ang3lus »
hey all,
i can't get any sound with this pedal, i've listed the voltages of the IC and tube , using 12ax7 and TL72CP
IC:
1: -15v
2: -14v
3: -13.23v
4: -15.1v
5: -13.23v
6: -13.6v
7: -13.53v
8: -13.94v
tube:
1: 0v
2: 12v
3: 11.5v
4: -3.9v
5: 0v
6: 0v
7: 11.8v
8: 11.3v
9: -5.3v
do the voltages look okay ?
checked with dc voltage, supply is 2A 16v AC
IC voltages look screwy - you should have +15v DC on pin 8 - check your power supply diode polarity as well as the input filter capacitors and the regulators
Ang3lus
Post by Ang3lus »
regulator should be pumping +15v ?
polarity is fine on the diodes and capacitor orientation also looks ok, none are bloated or look damaged also.
primary suspect now is the regulator
Ang3lus
Post by Ang3lus »
I'm getting at the input
17.2vAC
and after the diodes -23.1V DC
is it suspicious ?
