Tone Bender II transistor bias issue
Hello,
Would like to get some opinions on how to proceed here.
I am building the Aion Deimos, and having problems getting the transistors to bias correctly.
Here's the build doc : https://aionelectronics.com/wp-content/ ... tation.pdf
I am using a "Flying Dutchman" set of PNP Germanium transistors from Small Bear. They are marked as follows:
Q1 - Gain 64, Leakage 114
Q2 - Gain 75, Leakage 208
Q3 - Gain 116
Small Bear also included a set of resistors to use for R3, R4, and R6, which I did use instead of the values in the build doc, so my R3 is currently 27k instead of 47k and my R6 is currently 10k instead of 1k. (R4 remained at 100k)
This build also has a 50k trim pot on Q2 and a 10k trim pot on Q3.
The suggested readings in the build doc are -
Q1: C -8.5v B -0.05v E 0v
Q2: C -0.15v B -0.07v E 0v
Q3: C -8.5v B -0.15v E -0.1v
I cannot get to those values with the current setup. Here's the range I'm getting:
With both trims at 100% -
Q1: C -9.33v B -0.001v E 0v
Q2: C -0.55v B -0.03v E 0v
Q3: C -2.4v B -0.5v E -0.5v
With both trims at 0% -
Q2: C -1.2v B -0.04v E 0v
Q3: C -1.1v B -1.2v E -1v
I'm not entirely sure what I need to do from here. I'm guessing I will have to switch out resistors until I find the right combo. Can anyone give me a suggestion as to where to start?
I should mention that I have been through the rest of the circuit and tested all components and connections. Everything is good. I get bypass signal through the pedal. When engaged, my LED lights, but no sound.
Thanks for reading!
Q3 - Gain 116
Thanks for reading!
" One thing to keep in mind is that the Q2 bias trimmer actually adjusts the
bias of Q3 as well, while the Q3 pot only adjusts Q3. So, always bias Q2 first and then only use Q3’s bias
adjustment if you need to. The Q2 trimmer is going to be far more useful.
As a starting point, set the Q3 bias trimmer to around 75% rotation (approximately 8.2k total resistance
when combined with R6). Turn the Q2 bias trimmer all the way down. Then, with a multimeter, touch the black
(common) lead to ground and touch the red lead to the far-right leg of Q2. You’re looking for something near
these voltages.
Q1: Collector -8.5v, Base -0.05v, Emitter 0v
Q2: Collector -0.15v, Base -0.07v, Emitter 0v
Q3: Collector -8.5v, Base -0.15v, Emitter -0.1v
Since Q2’s voltages are so low, it’s best to test Q3’s collector as you adjust the Q2 trimmer and stop when
Q3 is where you want it. The Q3 bias trimmer should only be used if Q2’s voltage is way off once this is done.
this also might help you
Leakage (measured in microamps or μA) is important. Unlike most other transistor-based pedals, in this case
some leakage is required for it to function properly. You’re looking for somewhere between 100μA and 400μA
of leakage—any less than that and you might not get any signal past Q1. (Note that RX1 and RX2 have been
provided to simulate leakage on Q1 and Q3 if your transistors measure lower than the optimal range.)
The info above is from the build doc that you linked.
It looks like you need to have the right values before the signal goes through, it sounds like you have wired the pedal right just check the input and output too (i had these back to front before the bypass worked but no sound )
these voltages.
- Manfred
- Has thanked: 1675 times
- Been thanked: 1360 times
The base voltage of Q1 is determined by the collector base leakage current that flows through the 100 Kiloohms resistor between base and ground.he suggested readings in the build doc are -
Your read base voltage ist too low, I suppose that either the leak current ist to low or Q1 is defektive.
- Electric Warrior
Turned out it was both.Manfred wrote:The base voltage of Q1 is determined by the collector base leakage current that flows through the 100 Kiloohms resistor between base and ground.he suggested readings in the build doc are -
He used a 10k on Q1C, which certainly isn't enough for his low leakage transistors. Swapping it for a 100k made no difference, though, as the transistor is fried: https://www.diystompboxes.com/smfforum/ ... c=122972.0
