Nux looper core pedal malfunctioning
Hello people here
I have a nux looper core pedal suddenly lost it's dry signal.when I plugged it .the volume of this pedal suddenly the bypass signal or the sound of my guitar lessen like the volume is very weak now.but all the functions work well as normal..
Anybody here have this pedal and with same problem of mine???
Please give advice pls
- Intripped
the best thing you can do is to accurately inpect the PCBs, looking for something wrong - a disconnected cable, a broken solder joint, a burnt component... - you had better use a magnifier, a good one.
start checking very well the solder joints on the ribbon cable and on the relay (since jacks and pots are already ok)
I will describe what's happening when I turned on the pedal it sounds like there's a wind blowing ..like shhhh..sound at the same time with dry signal of my guitar that's so low.you can hear the strings when you strum it but so tiny low output..what this could be??
Any
body here has the same problem of this pedal??
Any
