Boss - CE300 Chorus - muting question
Lani
my favorite amplifier: Bassman 5f6a
Completed builds: .....ummmm yeah. Too many to list.....
Has thanked: 135 times
Been thanked: 93 times
Post by Lani »
Was looking over the schematic for this Boss rack effect and cant rap my head around what this muting circuit is doing (see attached schematic). What kind of signal is going to Q12 and Q16 gates? Or am I missing something obvious..... Maybe there is supposed to be a dot where it crosses with the ring connections on the rear output-1 and front output-B jacks? But i think that would mute the output right? I feel dumb. :scratch:
boss-ce300-chorus-schematic-muting circuit.pdf
(490.4 KiB) Downloaded 99 times
ppluis0
Has thanked: 127 times
Been thanked: 299 times
Post by ppluis0 »
Hi Lani,
Q17, Q19 and their associated components acts as a "soft start" time delay to mute temporarily (by means of Q12 and Q16) the outputs after turn on the unit.
This is intended to avoid "pops" until all supplies stabilize.
Lani
Post by Lani »
Hi ppluis,
Ahh I see.... so if i where to build this would you recommend keeping it in there or do you think i can lose it? I wont be turning it on and off. (The power that is). Bypassing via the other fets wont be effected if I take theese out right? Thanks for the info bud.
Lani
ppluis0
Post by ppluis0 »
If you take the precaution to power on all boxes, racks, processors, etc. prior to turn up the volume on your amp you can avoid the use of this feature.
