Redraw MXR M108 10 BAND EQ
enterx
Post by enterx »
I built this circuit and modified it from the MXR M108 Vintage Bluebox. Want to know if it was written correctly?
matmax44
Post by matmax44 »
Other question. Did you managed to build it? Does it work? If it does, what slides did you use for circuit? Have you found the value of "C4" cap?
CheapPedalCollector
Has thanked: 31 times
Been thanked: 18 times
Post by CheapPedalCollector »
Pots should be C taper (log/antilog)
