Silicon fuzz face hiss
Silvio55
Post by Silvio55 »
Hi, Just finished a silicon fuzz face, I used two 2n3904 hfe around 210 for both. Biased q2c lowering the colector resistor at 5.2 volts, q1c is at 1.45, with stock 33k resistor, the pedal works fine, but unlike my Ge FF, the more I turn down the guitar volume the more hiss (not buzz or hum) I have, especially when I turn down the volume down to zero. My Ge FF is more hissy in general but the hiss doesn't vary with my guitar volume, and when turn down to zero the hiss stops.
Any ideas? Thanks!
Has thanked: 596 times
Been thanked: 2061 times
stick a 100 ohm resistor in series with the dc supply and drop a 220 uf capacitor off the circuit side to ground ;-)
Silvio55
Post by Silvio55 »
bajaman wrote: 11 Apr 2021, 21:36 stick a 100 ohm resistor in series with the dc supply and drop a 220 uf capacitor off the circuit side to ground ;-)
I'm using battery, it would still be necessary the 100 ohm resistor? I will add that 220 uf filter cap and test. Thanks!
Silvio55
Post by Silvio55 »
The filter cap didn't help, but putting a 470 pf cap across colector and base of Q2 seemed to help, it stopped almost completely the hiss at zero volume but not the hiss at lower volumes. At higher volumes it doesn't hiss, (with or without the cap) why is that?
Edit: adding resistance in series at the input also helps, between 4 and 6k but I don't like how it changes the sound.
Manfred
Has thanked: 1675 times
Been thanked: 1359 times
Post by Manfred »
Sometimes the germanium transistor itself has a high self noise, the exchange of the transistor can solve this problem.
A bad transistor can be found by cooling it down with an icing spray, if the noise decreases noticeably in the cold state.
