Aion fx oceanid compressor
AndrewGallios
Post by AndrewGallios »
hi
i bought the oceanid pcb from aion fx
i built it and it was fine until i tested the buffered or truebypass section of the small pcb on the footswitch which i had to hardwire because i didnt have a switch so after solder and desolder that section 2-3 times so i can decide,the small pcb damaged and now the whole pedal is not working
i tried to wire it without the small pcb and wire it direct to the footswitch but i had no succes
anyone can help? i want to wire it without the small pcb direct to the footswitch
here is the link and photos
https://aionfx.com/app/files/docs/ocean ... tation.pdf
bmxguitarsbmx
Has thanked: 705 times
Been thanked: 216 times
Post by bmxguitarsbmx »
1) Youtube how to solder. 2) Youtube how to repair lifted pub traces. I would invest in a temperature controlled soldering iron. A good iron will heat it up to the right temperature quickly allowing for quick work. If you are having to sit for too long on a connection, pads will heat up enough that the glue that hold them on lets go. My guess is that you didn't have enough heat when trying to remove the jumpers. Your switch connection also looks like it tidbit have enough heat. I hope that is helpful.
AndrewGallios
thank you for the advice although my question was how to wire this without the small pcb which is not functioning right now
the damage is done ill take care in the next but now thats not the problem
Intripped
Has thanked: 990 times
Been thanked: 305 times
Post by Intripped »
Do you want the true bypass or the buffered version?
Do you have another 3PDT switch or are you using that one? De-soldering the switch from the small PCB may definitely damage the PCB and/or the switch itself
AndrewGallios
i want true bypass version
i have another 3PDT switch
Intripped
Post by Intripped »
Ok.
On your main PCB you have some connection pads:
In, gnd, +v, buf, fx.
fx is the out of the effect.
Ignore buf
Use the wiring diagram #5 on the pdf downloadable from tonepad (just ignore the battery snap wires). Google "tonepad offboard wiring"
AndrewGallios
it worked
thank you!
