First pedal no output
Hello everyone,
I'm new to the world of DIY pedals and just built my first kit "Musikding: The May"
The pedal works perfectly for the first 5 to 10 minutes, after which it starts buzzing intermittently until the sound is totally lost or extremely reduced. It feels like it stops working as it "warms up".
Switching the pedal off makes the effect true bypass and that's working perfectly, with clean sound from guitar to amp.
At the moment the back is open and the PCB is not in contact with anything.
How can I try and find where the problem can be?
- Manfred
- Has thanked: 1671 times
- Been thanked: 1344 times
Check the solder joints.
Measure the DC voltages at the transistor terminals when the device is working and when the error occurs.
Here is the circuit diagram and the wiring diagram.
Thanks for the answer,
I'll check everything later today.
With DC at the transistor terminals, you mean Voltages between Base/Collector, Base/Emitter? How can I know the kind of voltages I should expect?
- Manfred
No, the voltages on the transistor pins in respect to ground.With DC at the transistor terminals, you mean Voltages between Base/Collector, Base/Emitter? How can I know the kind of voltages I should expect?
In the case of the working circuit:
U_Base ~ 1.6V
U_Emitter ~ 1 V
U_Collector ~ 6V
I did check voltages and they are correct with the pedal "cold", I strum my guitar for few minutes and when the sound disappears the reading are:
U_Base - 2.54V
U_Emitter - 1.89V
U_Collector - 2.88V
Checking the joints later and let you know if I get any change!
U_Base - 2.54V
U_Emitter - 1.89V
U_Collector - 2.88V
I just checked all joints and they look "properly" done.
I checked all resistors during the error and R2 seems to drop to 18K, is it possible that this happen and could create this kind of problem?
I also replaced the transistor but even with the new one it seems to have the same problem...
- Manfred
Have you measured the resistors under voltage with the ohmmeter ?I checked all resistors during the error and R2 seems to drop to 18K, is it possible that this happen and could create this kind of problem?
This is not possible because the values will be measured wrong.
Does the transistor get warm in the 5 to 10 minutes when you play the guitar?
- Manfred
Some further questions.
Does the error set in abruptly or is the intermittent buzzing get worse over time?
Where does the operating voltage come from, battery, plug-in power supply, power plant or other power supply unit?
Did you build the circuit on the PCB from Musikding, on a stripboard or point to point?
It could also be that the circuit starts to oscillate.
I did check all resistor right before start playing and as soon I have the error. I just unplugged everything and test. I looks like that R2 value is fluctuation between 15K and 150K. As soon as the value stabilize at 100K, I can plug in and the pedal is temporary working again. I will try replacing that resistor today to see what happens.Manfred wrote: ↑25 Apr 2021, 23:14Have you measured the resistors under voltage with the ohmmeter ?I checked all resistors during the error and R2 seems to drop to 18K, is it possible that this happen and could create this kind of problem?
The transistor is staying cold for the whole time, and as mentioned, I've already checked with a new one, same problem.
The sound is perfect for few minutes, then it starts making some noise (the one you have when you use a loose jack plug and you move the cable: I don't know how to call it in English), at this point the sound fades out and it never comes back. Most of the times the "noise" stays when the pedal is turned on; if turned off at this point, the true bypass is working perfectly and I have sound out of the amp.
At the moment I'm using a 9V 1A power supply which I've always used with all my pedals in the past. I know it's not a proper one, but it always did the job at home. I also tried a second power supply with slight less amperage and 9V battery. Same problem with all of them.
I bought the one from Musikding with the PCB. About the oscillating part, I don't know how I could check that...
- Manfred
To see this you need an oscilloscope.About the oscillating part, I don't know how I could check that...
Where do the 2N5088 transistors come from, possibly from China?
I have already bought there transistors where it was not what is written on it, the values and the PIN assignment were wrong.
I could prove this with my semiconductor analyzer.
There are also good dealers but also black sheep.
- Manfred
Make a try and solder out the electrolytic capacitor and see what happens then.
You should hear a slightly higher volume than in bypass mode.
At this stage I removed almost everything... it's only the PCB, Jacks and power connector (tried both battery and power supply).
I removed the electrolytic capacitor C4 and also C2. I also replaced R2 with a new one and checked with a second transistor. Still the same problem.
I have nothing left to change basically...
- Manfred
Such a simple circuit and no solution to the problem this is unsatisfactory
Please post a photo of both sides of the board including wiring maybe you overlooked something.
- Manfred
The potentiometer or a 100k resistor to ground at the output is needed for a trial.
- idy
- Completed builds: FFs, Octavias, TBMKIIIs, Buzzarounds/alikes, Axis Fuzz', CS Overdriver, BMPs, Black '65s, MOSFETODs, WiiO, RAH, Klons, AC30, DLS, TSs and many variants, Small Clones, UniVibes, E. Mistress, Mutron Env Filter, Ross/Dynacomps,, EA Trems, TremLunes, Katana Boosters, BYOC Tri Boosters, other boosters and buffers, PT2399 delays, SKRM based delays, Belton Brick Reverbs, 3band parametric EQ,
- Has thanked: 27 times
- Been thanked: 31 times
When they say "check solder joints" they don't mean just look, but go over them again with the iron, reheat to make sure everything is connected. (not too long near the transistor, but your is socketed, sockets are often not good connections. Make sure it is firmly in place.) Often I've had things that look fine but a "cold solder" joint makes a bad connection.
You can't measure the value of a resistor when the power is on! And it is difficult to measure it "in circuit," but you can get some results, you have to look out for parallel R's or even a transistor that may act as a diode.
I would also, power off, measure for continuity between all the places that should be connected by the traces on the PCB. Sometimes a trace gets lifted or otherwise spoiled on a PCB, and although things look good, a connection is "open."
Not sure why you took out C2.
- Manfred
I had an idea and ran a simulaltion in which I changed the 2N5088 model.
I gave the transistor a larger base-collector reverse current of about 50 Mircoampere and I reached the approximate voltage values measured in the fault case.
The behavior in this order of magnitude is known only from the germanium transistors, there this reverse current increases with the heating in the time.
In this case the transistor must be faulty, how crazy that would be.
Try some other transistor type and pay attention to the pin assignment.
- Manfred
I forgot to mention that this reverse current or also called leakage current flows to ground via the R5 = 22k and thus increases the voltage drop across the resistor, which causes a shift of the bias point.
