Pedal is working and sounds good...all controls work fine.
*Proper 12v has been applied. (ACA pedal)
*happens w/ both external power & 9v Battery.
The ONLY thing that is not working is the LED does not light up when pedal activated.
Things I've tried...
*Changed out the LED for various other LEDs...Still issue remains.
*changed out D3...did not fix issue. Then installed it back.
Boss DM-2 ... LED not working despite new LED.
- lolbou
Check the 3k9 series resistor (R40) in the LED circuit (may be crack open) and wiring as well.
Can you measure the voltage at the LED changing when switching?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
