Pog original power issue
9 volt
Post by 9 volt »
Hi there, my pog when I plug in my pog to power the led flickers for a few seconds. During this time if I push the bypass switch it seems to crash. If I reconnect power a few times it starts up normally. I thought it seemed like a capacitor issue but they seem ok. Does anyone have any ideas? I’ve found some similar questions on line but no one seems to resolve it. Thanks
Intripped
Has thanked: 991 times
Been thanked: 305 times
Post by Intripped »
Dirty/rusty power jack?
9 volt
Post by 9 volt »
No such luck…. Thanks
phatt
Been thanked: 343 times
Post by phatt »
9 volt wrote: 20 Sep 2021, 00:32 If I reconnect power a few times it starts up normally.
I assume from that it does work sometimes?
Try wiggling the power plug (where it plugs into pog)
If it cuts in/out then highly likely the solder has cracked around the power socket.
It's a very common fail mode for many pedal supplies.
Phil.
