Tube preamp relay click on start up
Reachahighernoon
Has thanked: 43 times
Been thanked: 11 times
Post by Reachahighernoon »
OK so I built a tube preamp with 3 12AX7's running on 190VDC to the plate and 12V to the heaters. I use a SMPS to convert 12V to 190V and the whole thing is powered by a 12V 1A wallwart
On start up, when everything is cold, I plug the power and I hear audible clicking coming from the relay for several seconds until the tubes warm up, when the tubes are warm, nothing but standard operating noise
This is the schematic, any help would be appreciated
Manfred
Has thanked: 1675 times
Been thanked: 1359 times
Post by Manfred »
What is the circuit of the 12V supply?
The cold resistance of the 12AX7 is about half of the hot resistance which increases exponentially and is reached after about twenty seconds.
It could be that the 12V power supply or the heater winding of the transformer is weakly rated.
Then the ripple voltage before the voltage regulator could be so high that the output voltage of the regulator follows this and the relay switches off and on in time with the ripple frequency until the tubes are warm up.
Reachahighernoon
Manfred wrote: 27 Sep 2021, 16:37 What is the circuit of the 12V supply?
OK so I dont know about the circuit, it's a 12V wallwart that was recommended to me for this application, it is a switching power supply and not transformer based
I noticed that a similar issue happens on a similar preamp I built but it has no relay and only 2 tubes, the status LEDs switch on and off but for a shorter period of time cos the 12V supply only has to deal with 2 tubes instead of 3
I noticed that a lot of tube based pedals have a large cap before the heaters, I think this is the issue especially after you said "ripple"
plush
Has thanked: 36 times
Been thanked: 172 times
Post by plush »
My assumption is that SMPS wall wart goes into hiccup mode due to large inrush (especially if there's a lot of filtering/bypass caps present), then stabilizes after some time. This explains relay clicking.
Some SMPS don't like huge capacitive loads and/or don't have any intelligent inrush control.
Reachahighernoon
plush wrote: 27 Sep 2021, 17:46 My assumption is that SMPS wall wart goes into hiccup mode due to large inrush (especially if there's a lot of filtering/bypass caps present), then stabilizes after some time.
Which is weird cos these are the same wall warts that Effectrode sell
Wait wait, no they are not, the ones Effectrode use are rated at 1.5A and 18W, the ones I used are rated at 1A 12W. I just tried the Effectrode ones and they dont make that weird clicking
plush
Post by plush »
Reachahighernoon wrote: 27 Sep 2021, 17:47
I'm not really sure how relay control is implemented in effectrode and what capacitive load do they have.
I'm also not sure how do you control your relay.
The circuit you've provided is not complete and is missing some details. which may be critical for our investigation.
Reachahighernoon
plush wrote: 27 Sep 2021, 17:51
See my edit please
Also, my relay control is really simple, its just a switch that connects the coil to ground
plush
Post by plush »
Reachahighernoon wrote: 27 Sep 2021, 17:52 See my edit please
Well, I guess, we can mark this one as solved, right? :)
Reason = smps going into hiccup due to inrush.
Those provided by Effectrode may have higher inrush limit or deal with it in a different way.
Reachahighernoon
plush wrote: 27 Sep 2021, 17:54
Yeah pretty much, I guess the circuit is fine
I was sure this had something to do with the output current of the power supply
Thank you kindly
I assume a thermistor will help me? Or is the issue solely related to the supply?
Manfred
Post by Manfred »
The maximum inrush current of all filaments together is about 1.9 Amps for all tubes.
The mean value until the heating is finished is about 1.5 Amps.
The nominal value after the heating is 0,9 Amps.
Therefore I think that the power supply is too weak.
plush
Post by plush »
Reachahighernoon wrote: 27 Sep 2021, 18:00
Yep, NTC placed in series with VCC should work.
Relay soft start with a timer/voltage reference is also an option.
Reachahighernoon
plush wrote: 27 Sep 2021, 18:43
I just searched "tube amp inrush current" and thermistors id what came out
Thank you guys for the help
What value though? 100K? The schematics for typical thermistors it says 10ohm
Manfred
Post by Manfred »
Regulated PSU with Softstart:
