Demeter - Tremulator
Torchy
Post by Torchy »
lmkv15 - thanks, missed that one :oops:
didnt spot as I built mine on vero. thanks for all the tips, but I didnt have the problems others had, mine worked ok :?:
Hi Torchy - didn't have any problems building mine - just my simulations were weird - I will recheck them again - still puzzled about those 4.3v zeners though. Can anyone confirm they are correct :?:
Steve
invictus
Post by invictus »
bajaman wrote:Thank you lmkv15
I also took Invictus's advice but connected the pilot light led with 4.7k in series to pin 6 of the LF351 - I rerouted the red wire from the 3 pole switch and soldered directly to pin 6 on the board 8)
ooops...yeah, pin6 should be better point to connect it... gotta edit that one. another better thing to do is to attach the negative side of the LED to the 3PDT where it could connect to ground when the circuit is active, then disconnect ( LED OFF) when in bypass mode..
i'll try to edit the schematic and post it here for those who could use it..
"im the master of my fate, im the captain of my soul... " -invictus
Hi Invictus - I was going to switch the earth end too, but got lazy and just moved the red wire from +9v to pin 6 - it doesn't click or thump when switched :wink:
Hi folks
I ran some more simulations and I am now getting a perfect triangle wave oscillator - not lopsided or with rounded edges etc :?
Also the zeners have no effect on the simulated waveform or the physical implementation of this schematic - save your money and leave them out :? :?: :!:
Hello again
I have re-designed the Demeter oscillator section of the tremulator schematic posted by Torchy, which is just a badly designed triangle wave.
First - I simulated the schaller oscillator in markm's heart throb tremelo, and found it to be a lot similar in design to the classic Fender 12AX7 oscillator (phase shift oscillator type), but realised with an NPN bipolar transistor. However the sine wave function is not very clean and I suspect it cuts the transistor off on it's negative sweep - SO - I simulated an opamp version which gave a very clean sine wave, BUT needed a triple ganged pot to shift the frequency of oscillation.
OKAY - I googled and came up with a National Semiconductors application note using LM101 and LM111 devices.
After several hours simulating and adjusting this, I came up with a damn near perfect pure sine wave oscillator that only requires a single ganged 50k linear pot to tune from slow to super fast.
Armed with this new oscillator schematic, I attacked the demeter board, cutting and moving tracks and replacing components etc.
I retained the LF 442 op amp and reduced the gain of the led driver that follows the oscillator to 13dB (was 27dB).
I plugged my guitar in and WOW, this tremelo is smooth as :D No sign of any choppiness or uneven - sounds almost like a leslie on very fast setting ( which is something I will be using this oscillator in in future :wink: )
I wonder if I should give Ry Cooder a phone call :lol:
ANYWAY - Enough raving - I will redraw the board layout and schematic etc. and post for all to build in the next few days - YOU will like it much better than the Heart Throb or stock Demeter versions.
8)
Stay tuned
Kaos
my favorite amplifier: Fender Super Sonic
Post by Kaos »
The camel is a horse designed by a committee that never met.
No - but I had seen that one - far too complicated :wink: :lol:
the application note is National Semiconductor Linear Brief LB-16 from March 1971 (figure 1), but I warn you now - I have changed it significantly - just a good place to start - be patient I am redrawing the board layout and schematic at present.
Kaos
Post by Kaos »
thank you :)
i'm looking forward to see your schematic
Here is the schematic - board layout and pc tracks to follow :wink:
Baja Trembulator Schematic
Goop_buster
Been thanked: 7 times
Post by Goop_buster »
Great stuff bajaman, thanks ! :D
Hi Goopbuster - you are most welcome friend.
i plan to use this oscillator in an upcoming rotary speaker simulator - but don't hold your breath, other things to do first. :lol:
Try it out - i think you will like what you hear :wink:
Here is the printed circuit board track layout for my Baja Trembulator
( board placement to follow soon )
enjoy
Baja Trembulator Tracks
Here is the parts layout for my Baja Trembulator :wink:
Baja Trembulator Board layout
invictus
Post by invictus »
superb job bajaman! thanks for this..
any suggestion for a good replacements for the LFXXX ICs? i want to try your creation. but i dont have any LFXXX ic here.
is your perfect sinewave oscillator (PSO? ) strictly designed for LFXXX IC?
ANY dual opamp will do - TL072 works fine and even a 4558 of any manufacturer will work.
Eventually I will redesign for a TL074 quad opamp to do the lot :!:
You can use pretty well anything in here - experiment - use IC sockets etc.
I made my own optocoupler - see previous post in this thread.
Goop_buster
Thanks a lot bajaman :lol: .
What (frequency) is the slowest setting on that oscillator?
invictus
Post by invictus »
ok thanks... i will give it a try when i have some time...
Slow as you would ever need - if you change the 50k lin pot for a 500k lin you will get very sloooooow speeeed
ALSO if you want to get it running ridiculously fast lower or short out the 10k resistor in series with the rate (speed) pot.
You may like to put a 20k trim pot ( replace 18k) in the feedback loop of the LF351 ( or TL071) etc., to adjust the optocoupler light intensity also.
bajaman - falling asleep - 1:13am here - yawn - back tomorrow ( or later on today) :lol:
