Guild - FW-3 ( Fuzz-Wah )  [schematic]
Been thanked: 124 times
Is a cousin of the Applied/Kadent/Goya pedals.
I wonder who was the secret builder behind all this stuff.
jrod
Has thanked: 425 times
Been thanked: 46 times
Post by jrod »
Just found this schematic on ebay.
WRONG SCHEMATIC, check redraw later in the thread by EHman
And sadly this schematic is wrong.....
jrod
Post by jrod »
Anyone know if there is a correct schematic for this unit?
I am mainly interested in the fuzz section.
borislavgajic
Has thanked: 131 times
Been thanked: 281 times
Post by borislavgajic »
analogguru wrote:And sadly this schematic is wrong.....
....How do you know that mister AG ?...... :D
please can you tell what is not OK with this one?
many thanks
Boris
jrod
Post by jrod »
http://tonebender.webs.com/fuzz.htm
Boris & AG - Check out this U.M.I. Buzz Tone schematic. There are some similarities between this and the Guild FW-3 fuzz section. I am leaning toward the FW-3 being the same circuit as U.M.I unit since AG pointed out the schematic I posted is incorrect. With a little rearranging the FW-3 schematic can be made to look nearly identical to the U.M.I..
borislavgajic
jrod wrote:Boris & AG - Check out this U.M.I. Buzz Tone schematic. There are some similarities between this and the Guild FW-3 fuzz section. I am leaning toward the FW-3 being the same circuit as U.M.I unit since AG pointed out the schematic I posted is incorrect. With a little rearranging the FW-3 schematic can be made to look nearly identical to the U.M.I..
this is job for AG....my knowledge if far from his :secret: .........so if he could explain,you 'll get 100% correct answer :thumbsup
jrod
Post by jrod »
There are actually some pretty good gut shots at discofreq's site: http://www.effectsdatabase.com/model/guild/fw3
and more component side from the Nomad Fuzz Wah: http://www.effectsdatabase.com/model/nomad/fuzzwah
theehman
Has thanked: 98 times
Been thanked: 105 times
Post by theehman »
many thanks
Boris
Yes, please enlighten us. Is the fuzz wrong or is it the wah? Or both?
I'm tracing mine out now.
Ron Neely II
fx schematics and repairs
theehman
Post by theehman »
Here's what I ended up with after tracing mine out. LMK if you see any problems and I'll get it fixed.
Ron Neely II
Funny how the numbers of wrong schematics increase, even when the mistakes are obvious.
BTW, the Guild FW-3 NEVER has been made by Shin-ei, instead it was made by APPLIED AUDIO (should be even written on the track side).
@theehman
could you solve the problems with the Rogue Fuzz ?
theehman
Post by theehman »
analogguru wrote:Funny how the numbers of wrong schematics increase, even when the mistakes are obvious.
@theehman
No, I just threw the Rogue aside for the moment.
My error on the Shinei thing. Can you point me to any other errors on the schematic so I can double-check it?
Ron Neely II
I didn´t control everything yet, but the 220k at the input of the wah section is wrong and should be 56k instead. The 10n feedback-cap shouldn´t be connected to the base, instead it should be connected to the junction between the 1k5 and the coil.
theehman
Post by theehman »
analogguru wrote:I didn´t control everything yet, but the 220k at the input of the wah section is wrong and should be 56k instead. The 10n feedback-cap shouldn´t be connected to the base, instead it should be connected to the junction between the 1k5 and the coil.
You're right about the 18n feedback cap but on my unit it does have the 220k at the wah input, not 56k. It seems to vary as I've traced out a couple of Guild wahs and found 68k and 100k in that spot.
Ron Neely II
jrod
Post by jrod »
Can't wait to see how your trace comes out, ehman!
Did the fuzz section look anything like schem I posted?
theehman
Post by theehman »
jrod wrote:Can't wait to see how your trace comes out, ehman!
It looked like the one on the original Guild schematic, with a few parts differences. The wah was completely different, though.
Ron Neely II
the3secondrule
Completed builds: GGG Phase45
Fuzz Factory Clone
Shin Ei Companion Fuzz
EHX LPB
Fuzz Face
Zvex Machine
GGG Green Ringer
woolly mammoth
SHO
Microamp
Noise swash
Phaseur Fleur
Catalinbread SVT
valvecaster
CE2 Chorus
Aquapuss
Has thanked: 24 times
Been thanked: 13 times
Post by the3secondrule »
@theehman - did you end up finishing tracing out the schem? I have a friend who want s a clone of the fuzz section only - was it comparable to the UMI fuzztone schem posted above at all?
Jeremy
"Rock music is mostly about moving big black boxes from one side of town to the other in the back of your car."
theehman
Post by theehman »
the3secondrule wrote:@theehman - did you end up finishing tracing out the schem? I have a friend who want s a clone of the fuzz section only - was it comparable to the UMI fuzztone schem posted above at all?
Jeremy
It was pretty much the same as the Guild schematic posted earlier.
Ron Neely II
the3secondrule
Fuzz Factory Clone
EHX LPB
Fuzz Face
Zvex Machine
GGG Green Ringer
woolly mammoth
SHO
Microamp
Noise swash
Phaseur Fleur
Catalinbread SVT
valvecaster
CE2 Chorus
Aquapuss
Soooooo... i have just been "donated" one of these. It's in pretty poor condition. most definately not in working order. definately some components missing :shock:
I'll get some guts up if anyone is interested, but it seems pretty well documented already.
how does this guy sound?
anyone got any sound samples?
I'm wondering whether it is worth trying to get this puppy running again, or if I should gut it, and put something else in there (thinking maybe a superfuzz clone, with either a chicken salad or a wah...)
