StripMagic 0.1b
~arph
Has thanked: 51 times
Been thanked: 155 times
Post by ~arph »
Hi All,
I found some time to work on this last evening.
I've made some updates available, which I hope you like.
New features:
- Place wires
- Place Potentiometer
- Place Timmers
- Select electrolyte size
- All components con now be placed offboard.
- Jumpers can be drawn at any angle
- Enter key in the value field of the component editor will save and exit
- PERFBOARD option selectable in the Board Properties dialog.
I hope you like it.
URL as always:
http://www.friedair.com/stripmagic/start.jnlp
~arph
Post by ~arph »
Sneak peek:
~arph
Post by ~arph »
Breadboard option is available! :)
Has thanked: 3209 times
Been thanked: 667 times
Nice works Arph, really... :applause:
Has thanked: 121 times
Been thanked: 101 times
yes, the latest version is working great! :mrgreen:
i spoke too soon. :?
i just was working on a layout, hit NEW, then SAVE, then tried to pull up the old layout(which i had saved previously), and a blank board came up. if i hit NEW, why did it automatically save it under the old file name? i also had a problem where the last time i used the save command on a layout, it didn't take. anybody else report a similar problem?
~arph
Post by ~arph »
I'll do some testing on this.
Meanwhile, if someone has some good icons for the components, or the skill to create some, I will be forever gratefull :D
Regards,
Arnoud
Dr Tony Balls
Been thanked: 102 times
Post by Dr Tony Balls »
Arnoud,
Thanks again for this! I use it all the time, and its a nice little tool that gets the job done simply and effectively. Has any thought been given to changing the component font so that parts are more easily identifiable? I mentioned it once before but when a resistor is in a "standing" position, the lead and the resistor indicator ("R2", for example) get kind of jumbled up.
it would be great to be able to adjust the size of the text for titles and the like as well.
~arph
Post by ~arph »
Thanks for the kind words. Fonts and text in general are a pain in the b:oops:tt in OpenGL.
What I really want on the components is text with an outline (like black text with a small white outline and the same inverted).
Adjusting the text tool so you can choose fontsize and color should not be a problem, I can fix that up soon.
But I have to step away from full interoperability between this tool and DIYLC. Because there features on the list now that are not supported in diylc yet. I can do a separate export/import still though.
~arph wrote:Hi,
i wouldn't worry too much about that. just keep on workin on making the best program you can! hopefully it can exceed the competition. (no offense to DIYLC, of course.)
~arph
Post by ~arph »
Sparked by a PM. I did a quick release of what I have done so far.
Now it's possible to:
- Select RGB wire and Cap colors
- Select font size, style and color
- Save as a diyx file.. which indicates that it contains extended diylc functionality. Not sure if the files will open there.
- Added the switch component
- Made text on components stand out with a small outline
- Fixed setting board type when openging a saved file
- IC's with more then 8 pins drawn correctly now
- IC connectivity highlight now works on all pins (usefull for breadboard and perf)
- You can rotate components (through the menu or with the R key)
- Delete button on keyboard works on selected component(s)
Working on Jacks..
Have fun!!
Grendahl
Been thanked: 7 times
Post by Grendahl »
Looks great!
The one issue I have with it is that after I rotate a part I don't see how to move it into position. What am I missing here? :slap:
Resistance is futile...
( if < 1 ohm )
~arph
Post by ~arph »
Hi
The fastest way is:
- Choose the select tool (looks like the mousepointer)
- Click on, or drag a square around the rotated component
- The component should now have purple highlighted nodes
- Drag the component to its desired place
You can only drag a whole component when the nodes are purple. You can drag single nodes when they are green or white.
Grendahl
Post by Grendahl »
~arph wrote:Hi
The fastest way is:
That's what I was missing. Thank you!
( if < 1 ohm )
~arph
Post by ~arph »
I'm getting some requests again lately. I'll be investing some time again soon
Hides-His-Eyes
Has thanked: 47 times
Been thanked: 63 times
Post by Hides-His-Eyes »
I could really have done with an offline version in the last few months but now I'm online at home again it's nice to go back to stripmagic. Not sure what exactly I'd request though, does everything I need :)
perhaps a way to have multiple boards on at once?
~arph
Post by ~arph »
It should work offline too.. you just have to make a shortcut via the webstart console..
Hides-His-Eyes
~arph wrote:It should work offline too.. you just have to make a shortcut via the webstart console..
How do I do that?
~arph
Post by ~arph »
you start the console by typing:
javaws -viewer
from the command line or in the start-> run menu
Then it will start a Java control panel. Also a window called the Java Cache Viewer will popup.
Here you can right-click on stripmagic and choose -> install shortcuts
This will place icons on your desktop. Next time you run it, it will look for the latest online version, if it can't connect it will start the cached application
Regards,
Arnoud
Hides-His-Eyes
Wonderful. Thank you!
