Dual Ruby amp
Dual Ruby amp
Postby Seiche » 01 Dec 2010, 17:31
Hey Guys,
i've been thinking about building a ruby amp. My idea was to incorporate two ruby's in one box, one standard and one with a bassman mod, and make them switchable so that i can run them one at a time or both (sorta like the guitar pickups of a les paul). I would like to do this with a single 8Ohm speaker. Any ideas how to wire this up, if its even possible?
Also when i run them in parallel, is the wattage gonna be 1W, hence do the wattages add up (Single Ruby = .5W afaik)?
hope you guys can help
cheers :thumbsup
Seiche
Has thanked: 266 times
Have thanks: 216 times
Re: Dual Ruby amp
Postby bluestomp » 02 Dec 2010, 11:32
Hi Seiche,
maybe you can put idea for litle rebell 2, just go to http://www.scribd.com/doc/35633615/Little-Rebel-2W-Guitar-Amplifier
thus use LM386 too.
thanks and regards
bluestomp
Have thanks: 3 times
Re: Dual Ruby amp
Postby RnFR » 02 Dec 2010, 13:56
bluestomp wrote:Hi Seiche,
thus use LM386 too.
thanks and regards
Thanks bluestomp, there is some very interesting stuff going on in that little amp! I like the gain control that brightens up as you lower the gain, and that eq definitely deserves another look. of course the parallel 386s for 5w( :shock:) is rather novel as well. But, i have to admit, I'm still wondering how that 5w is possible out of 2 1/2w chips.
Has thanked: 150 times
Have thanks: 176 times
Return to Amplifiers
Users browsing this forum: MSN [Bot] and 3 guests
