The Sweeper
I have one of these. It works, though it is part now. The footswitch is missing.
Anyone ever seen or heard one? Kind of a funky little box that I'd like to get back together once I order a switch.
Here is an ebay auction of one for reference. This is not my auction!;
ricker
ricker
- rocklander
- Has thanked: 1406 times
- Been thanked: 231 times
- Contact:
do you have the facility to take gutshots?
- rocklander
- Contact:
can't find much info on the TA75747P
on google, I see an AD7574 8 bit DAC.. (whatever that means)
- pedalgrinder
an 8 bit dac is a digital to analog converter 8 bit but i very much doubt thats what its using i also searched the net high low up and down and found nothing on that IC bit of a mystery hardly worth tracing if we can't work out what the ic is.
- mictester
It's a cheap dual op-amp. Back in the 1980s it was considered "low noise".rocklander wrote:can't find much info on the TA75747P
Looking at the effect, it looks very much like an unusual layout for a basic four-stage phaser.
- tube-exorcist
Since when a (dual) 741 was considered "low noise" back in the 1980s ?mictester wrote:It's a cheap dual op-amp. Back in the 1980s it was considered "low noise".rocklander wrote:can't find much info on the TA75747P
TA75747P = µA747 = dual 741
- pedalgrinder
The problem here is not working where the tracks go and the values it's what are the TA75747p Toshiba chip is. Once thats worked out the pedal can be traced and schematic can be created.
- tube-exorcist
Careful reading can be helpful occasionally:pedalgrinder wrote:The problem here is not working where the tracks go and the values it's what are the TA75747p Toshiba chip is. Once thats worked out the pedal can be traced and schematic can be created.
µA747 = LM747tube-exorcist wrote:TA75747P = µA747 = dual 741
www.national.com/ds/LM/LM747.pdf
- mictester
According to the specification I've seen, it was supposed to be akin to a dual 741S (which was the "low noise" version). I always suspected that the "S" versions were just "selected" - the ones that hissed a bit less in their test jigs! I remember these ICs being used in Marantz tuners as the audio output buffers!tube-exorcist wrote:Since when a (dual) 741 was considered "low noise" back in the 1980s ?mictester wrote:It's a cheap dual op-amp. Back in the 1980s it was considered "low noise".rocklander wrote:can't find much info on the TA75747P
- pedalgrinder
If thats just a dual 741 why is it so damn hard to find out what it is. I read exactly the letters i could see on the chip. What else can you go by. Is there somewhere online i don't know about. Or is that from experience you know that chip is that. I don't say that sarcastically i want to know how you did it so i can in the future. Thanks
