D*A*M - 1966 Italian Tone Bender
Original effect designs complete with schematics, layouts and instructions. Freely contributed by members or found in printed or online publications. Cannot be used for commercial purposes without consent of the respective owners of the copyright.
beedotman
Has thanked: 394 times
Been thanked: 391 times
Post by beedotman »
Yo!
Layout for latest revision of D*A*M 1966 (sadly discontinued)- vox tone bender replica.
Instead of switching output capacitors as in old version - in new, super bee switch changes resistance of output pot from 470K (super bee mode) to ~42K (1966 mode) - really fun mod! Another change due to old layout - now bias trimpot is on Q1 collector.
Instead mounting two output parallel capacitors (C3 - Iskra's 4700pF and C6 - Xicon 2200pF) - You can remove C6 and change C3 to higher value to (6800pf will be the closest value, but 8200pf/10nf/15nf sounds cool, too).
Enjoy! :thumbsup
beedotman
Post by beedotman »
and here's pic of hidden cap under board
Has thanked: 147 times
Been thanked: 138 times
I know there are standoffs and all, but man, I would've definitely put some insulation on the leads of that cap on the bottom of the board.
beedotman
Post by beedotman »
RnFR wrote:I know there are standoffs and all, but man, I would've definitely put some insulation on the leads of that cap on the bottom of the board.
true! :thumbsup
beedotman
Post by beedotman »
And some more guts with different trannies combo - Texas Instruments OC82D + Mullard OC76 and Mullars OC71 + OC83.
beedotman
Post by beedotman »
Redrawn layout with full wiring under turretboard.org label :horsey:
1966.pdf
(20.23 KiB) Downloaded 188 times
Has thanked: 1111 times
Been thanked: 955 times
:mrgreen: My new project maker! Thank you in words :thumbsup
beedotman
Post by beedotman »
sinner wrote::mrgreen: My new project maker! Thank you in words :thumbsup
[smilie=drink.gif]
Solidhex
Has thanked: 10 times
Been thanked: 15 times
Post by Solidhex »
Those are half inch standoffs. If you're worried about those legs shorting to the enclosure its not really a possibility.
G5120fx
Has thanked: 37 times
Been thanked: 30 times
Post by G5120fx »
I´ve build it yesterday, and its a nice sounding fuzz! I used Ac122´s (as always, I bought 100 pieces once).
It´s supposed to have not much sustain right? Italian Tone Bender --> Spaghetti Western --> little sustain right?
beedotman
Post by beedotman »
G5120fx wrote:I´ve build it yesterday, and its a nice sounding fuzz! I used Ac122´s (as always, I bought 100 pieces once).
How short is sustain? It shouldn;t have sustain similar to let say Buzzaround or MKII, but it shouldn't be very short though...
G5120fx
Post by G5120fx »
ok, there must be something wring then. The sustain is shorter compared to the MKII.
I´ll check it again... Which hfe´s did you use?
beedotman
Post by beedotman »
G5120fx wrote:ok, there must be something wring then. The sustain is shorter compared to the MKII.
It' dependts... usually Q1 around 60-75 and Q2 70-110.
beedotman
Post by beedotman »
small veroboard version with bias on Q2C and socketed trannies
should fit 1590B or 125B easily
66_fuzz.pdf
(71.94 KiB) Downloaded 120 times
agoldoor
Has thanked: 39 times
Been thanked: 20 times
Post by agoldoor »
beedotman wrote:Redrawn layout with full wiring under turretboard.org label :horsey:
Pics of a build I did with this layout:
photo (17).JPG (57.54 KiB) Viewed 2967 times
controller700
Post by controller700 »
That is a great looking 1966!
From where did you get the rotary switch? I can´t find a rotary with only two positions...
What hfe values did you use for the trannies, and how close does it get to the "real thing"? 8)
beedotman
Post by beedotman »
controller700 wrote:That is a great looking 1966!
It dont need to be two position rotary switch, it could be with three or four positions - You can always limit amount of positions on rotary switches. Good idea is to use 3 pos. switch, two for mode changes and third for switch off battery.
controller700
Great idea! :thumbsup
I never used these before..
beedotman
Post by beedotman »
Here's for example 12 position 1 pole switch - top view.
In red are marked slots that You can use to limit number of positions from 2 up to 11, it's really quite easy to do :thumbsup
G5120fx
Post by G5120fx »
I built the new vero yesterday, and i really like it. It´s a little too dark sounding with my Gretsch?! Should I experiment with the 6,8nf to get a bit more treble?
THX
