Fairfield Circuitry - The Unpleasant Surprise
- DWBH
http://www.fairfieldcircuitry.com/US.html
Holy smokes. I bet there's an untraceable 4 layer board inside, just like the Four Eyes, but still...
I'm not usually interested in noise boxes - well, I think they're cool and all but I wouldn't certainly buy one. But this... oh my, I could see me buy one of these.
- greigoroth
Yep! I'm broke till Christmas otherwise I'd preorder - never wanted a "noise" pedal before, but this thing's something else. If nothing else I'd buy it for the controls - with the exception of "volume" I have no idea what any of them doDWBH wrote:http://www.fairfieldcircuitry.com/US.html
On the other hand, volume could be some sort of trickery...
- earthtonesaudio
- Transistor Tuner
Digging the sound samples very much on this one.
Gotta disagree on the "untraceable" four-layer board comment though. If it's analog, it's traceable.
- DWBH
It was just a joke regarding the pcb that's on their other fuzz pedalearthtonesaudio wrote:Digging the sound samples very much on this one.
- diagrammatiks
love fairfield.
only builder I know who discontinued a pedal because it was too complicated and too much of a clusterfuck to build.
respect.
respect.
- dlab
- Completed builds: TS808 / BYOC Phase Royale / Zendrive / Random Number Generator / Fuzz Face / SD-1 (modded to Keeley specs) / miscellaneous repairs and mods (replacement of pots, LEDs and 3PDTs, jack re-wiring, adding 9V jack, etc)
- Has thanked: 6 times
Isn't that what happened to the Foxrox TZF too? Too complicated to keep in production?
- Whoismarykelly
A better way to say it would be "not tracable by posting pictures of the circuit board on a web forum for knowledgable folks to guess at."earthtonesaudio wrote:Digging the sound samples very much on this one.
- earthtonesaudio
- Transistor Tuner
Quite right. The knowledgeable person, the pedal in question, and some tools must all be in the same place at the same time.
In this day and age that's actually pretty good security!
- diagrammatiks
i think the caveat is non-destructive tracing.earthtonesaudio wrote:Quite right. The knowledgeable person, the pedal in question, and some tools must all be in the same place at the same time.
anybody could trace anything by dismantling it.
- Whoismarykelly
Dude designs gorgeous PCBs. That actually doesn't look like anything more than maybe a double sided board based on the traces in sight. I'm looking forward to the one of these I have coming in the mail
- Gila_Crisis
any more infos about what's inside this pedal?
- Nocentelli
- Has thanked: 1155 times
- Been thanked: 954 times
My guess:
Input goes to a state variable filter (3 opamps or a dual OTA), LP output goes to low fuzz circuit, BP goes to Mid fuzz circuit, HP goes to Hi fuzz circuit. Some sort of dualgang pot controls the crossover frequency, simple switch to adjust feedback resistor for variable resonance, Lo/Mid/Hi controls are gain controls for each independant circuit, simple blend to mix the three outputs.
- Gila_Crisis
- Nocentelli
doh.Gila_Crisis wrote:I think you are guessing about the Four Eye fuzz.....
- allesz
It's an interesting pedal, the second pic is really good, but it's impossible to read the values.
I find strange that the only non smd parts are the two transistors....
- Completed builds: Shinei FY-2, D*A*M Meathead, Mid-Fi Electronics Deluxe Pitch Pirate, Clarinot, Demo Tape Fuzz, Random Number Generator, Wattson EFY-6, Smallsound/Bigsound Mini, DBA Reverberation Machine, Parasit Studio Raygun Youth, Vox Repeat Percussion, 1776 Multiplex Echo Machine, David Rolo Twin Peaks, Giant Hogweed, Devi Ever Soda Meiser, ZVEX Machine, SHO, Fat Fuzz Factory.
- Has thanked: 37 times
- Been thanked: 5 times
Ha, which pedal was that then?diagrammatiks wrote:love fairfield.
respect.
- Nocentelli
Come on, Bugg, get the schematic up
