Montarbo - Sinfhoton ( Fuzz )
ik6gpy
Has thanked: 19 times
Been thanked: 16 times
Post by ik6gpy »
Hi Sinner,
These are the ones i've got on my hard drive. Hope it helps
Mat
Been thanked: 909 times
Sure it helps bro, thanks :)
I was hoping to see SINPHOTON_schem2.jpg in better (bigger) quality, but this what I have should be ok
ik6gpy
Post by ik6gpy »
Here it is... Better quality e bigger schematic
Thanks, you're my hero. So... We have 3 schematics in this topic and they're all different. Basic topology is the same, but some caps and resistor value differs. I bet they're all good, revisions and versions during production perhaps? But could you point me the best sounding one?
I've took factory schemo and did perf layout similar to stock one. There is not much gutshots on the web, I was limited to one only, but I think I nail it quite nice
LucifersTrip
my favorite amplifier: Companion Psychedelic Machine
Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
Been thanked: 71 times
Post by LucifersTrip »
....was going to do a build report, but there didn't seem to be much interest at the time...
I did a bunch of tweaking and the only way this thing fired up for me was with high gain transistors and a bunch of resistor changes. Here's my final version with voltage readings:
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
Can someone please upload a bigger version of the V2 veroboard layout?
It seems to be one of the many attachements that got lost during the server change...
Solidhex
Has thanked: 10 times
Post by Solidhex »
Remove the 100K in parallel with the first set of clipping diodes for more fuzz...
DesertCruiser
Been thanked: 32 times
Post by DesertCruiser »
Solidhex wrote:Remove the 100K in parallel with the first set of clipping diodes for more fuzz...
Yeah that would be the best thing to do if you want more bite to the sound. I really like this fuzz, very good for fat power chords and its very quiet, it kinda have this noise gate quality. My russian BMP clone got a rival :lol:
Don't recreate - create!
(exept when it comes to puttin' Mel Schacher in a box)
sunburnedgoat
Post by sunburnedgoat »
I breadboarded this and fell in love. It's the fat fuzzy characteristics of a Muff, but there is better string clarity and chords sound great on it. It also cleans up VERY well with the guitar's volume knob. I also like the very slight differences in the diode pairs' configurations, from the Muff's.
I built one on terminal strips, but still wanted a small enclosure, so I came up with a weird method. Definitely gotta build in layers! :D
LucifersTrip
sunburnedgoat wrote:I breadboarded this and fell in love.
very cool...and looks great!
did you make any changes? transistors used? collector voltage on Q2?
sunburnedgoat
Ahh, yes. The good stuff.
Q1 - B: .6, C: 1.96
Q2 - B: .58, C: 5.25
Mods: I used 10uf electrolytics in place of the 2.2. I removed the 100k parallel resistor in the first diode set, as recommended. Mine is the 2-knob version. I added a switchable .1uf cap to ground on the input, which opens it up a little more - a little bit of sparkle, subtle increase in vol and compression.
sunburnedgoat
Oh... and 2n5089. Both read about 580 hfe. Mine fired up immediately when I first put it on the board, and I didn't have to modify any resistor values in order to get it to fire up, as reported previously. It's a mean machine. Loud and dirty.
LucifersTrip
sunburnedgoat wrote:Ahh, yes. The good stuff.
Q1 - B: .6, C: 1.96
thanx alot...I appreciate it. It's always cool to have other working voltages.
Did you try to move Q2C voltage up & down to see where you liked it best? I definitely wouldn't call what I got "dirty". I'd call it fat, chunky & smooth....with excellent sustain.
DrNomis
Has thanked: 98 times
Been thanked: 279 times
Post by DrNomis »
I wonder if MPSA 13, and MPSA 14 transistors will work in this circuit, I think I've got some stashed away somewhere, HFE is something like 10,000 or so.... :hmmm:
LucifersTrip
DrNomis wrote:I wonder if MPSA 13, and MPSA 14 transistors will work in this circuit, I think I've got some stashed away somewhere, HFE is something like 10,000 or so.... :hmmm:
I think I actually tried that and they didn't...you would have to re-design the circuit for darlington. I just went with the highest hfe I had, MPSA18
you should try em, anyway. my memory could be off.
Nico3p
Post by Nico3p »
Cambia qualcosa se al posto degli elettrolitici vengono montati dei condensatori al tantalio (per rendere più bassi i componenti)?
johnk
Has thanked: 36 times
Been thanked: 293 times
Post by johnk »
I just finished drawing up, etched and built a PCB for it and it sounds awesome.
I used MSPA18 transistors but had to adjust the two 10K collector resistors to get the transistors to sound good. with the stock 10K's I was only getting 1.6V on the collectors and although the circuit worked, it sounded horrible and very gated.
I replaced them 2.2K's and get 3.7V and it's smooth and silky.
I also added a gain control so I can lower the amount of fuzz if I want to.
here's the PCB layout:
johnk
Post by johnk »
here's my completed build in an etched enclosure:
Wiseblood
Has thanked: 78 times
Post by Wiseblood »
Nice build johnk, what is that switching you're using?
