Completely asinine question. (Re: Battery Clips)
How do you (mount/attach/secure) a battery clip to the inside of an enclosure. I've been at this for a couple of years now, and it just slays me that in that time I've learned how to build and even design my own effects with op-amps, transistors, mosfets, etc., but I still can't keep my batteries from banging around. I have those silver, 9v battery clips. I've tried a touch of JB weld and epoxy, no dice. Anyone?
- DrNomis
- Has thanked: 98 times
- Been thanked: 279 times
I simply use a small M3 bolt/nut combination to hold the clip in place....works for me....
- Dr Tony Balls
I have the same gripe. I do use a pop riveter to hold battery clips in place, and hold it does. However the the little stump that the riveter leaves on the back side is maddening and it takes up room inside the battery clip and makes the battery not fit. For example, these clips from Eagle Plastics hold the battery great before theyre mounted, but after they have the rivet stump sticking through them the battery doesnt completely seat in the clip.
The only solution ive found so far is to use these clips that Pedal Parts Plus sells. They dont really have a retaining lip like the Eagle ones so the battery can fit in there snugly without being fully seated.
The thing is that i'd LIKE to use the Eagle ones. Partly because i have a lot of them sitting around, and party because i really like doing one stop shopping at Mouser! How the hell do you guys get those things to work?!?
- Dr Tony Balls
FiveseveN wrote:How about some strong adhesive instead?
That never works. Epoxy and stuff like it is strong, but when you put a battery in the clip, the clip flexes and usually pops right off of the enclosure. It doesnt help that there's not much on an enclosure surface for the epoxy to grab onto, either. Beyond all that...its kind of a pain. There SHOULD be a way to do it all mechanically.
I suppose one option would be to use the 3M "red-back" double stick foam tape, but again a mechanical linkage would be superb.
- KindaFuzzy
- Degoop Doctor
The way I've been doing it lately is drilling a hole in the back of the enclosure, then threading it with a tap and die kit so I can screw the clip right to the back. Just have to file off the screw so it's flush to the back. A 4-40 screw usually has a small enough head to still get the battery in.
- Duckman
- Opamp Operator
Also, I use this kind of plier that let me do the job easily.
- Dr Tony Balls
Eh...but then the Rivet Stump is on the outside of the box, which aesthetically would drive me bananas.
- timbo_93631
- my favorite amplifier: Low wattage SE amps
- Completed builds: Many many many true bypass and voicing mods on wahs.
A few BYOC kits and DS-1 mods and eventual murder then rebirth into an actually useful pedal, Bad Stone clone, various Rangemasters/SilconMasterBlaster, The worlds greatest gutted GCB-95 volume pedal conversion with various switching options for controlling amps. Repaired many tube amps, scratchbuilt Marshall 18 watt clone and Supro 1616t rebuild. Delays, fuzz, dirt, every Madbean project I could afford. I even manage to find time to make babies with my wife too! - Location: Fresno, Ca
- Has thanked: 14 times
- Been thanked: 33 times
You could use something like a mesh battery bag you'd use in an acoustic guitar with soundhole mounted preamp controls where you don't want to put holes in the sides of the guitar for a battery box. http://www.stewmac.com/shop/Electronics ... y_Bag.html
But that is pretty expensive like everything from Stew-Mac...
If I have to have a battery (I am planning on selling the pedal in the future), I just mount my 3PDT so it sandwiches the battery with the side wall of the enclosure and then glue on a thin bit of foam on the enclosure side as needed to make it real snug so it won't move from side to side easliy. Not really an issue in 1590b's and 125b's but in a 1590bb snugness is key. For my personal builds I forgo the battery so I can use a smaller enclosure and save space on my pedalboard.
"I wish to be in the situation of non killing my balls bills, and life surprises." -Sinner
"Everyone gets their shorts in a twist over who polished the fenders. No one cares about who designed the engine..." -DougH
- Duckman
- Opamp Operator
Yeap, but it's a little one... well, two... in the underside. After file work, you'll see nothing but two little nipples.Dr Tony Balls wrote:Eh...but then the Rivet Stump is on the outside of the box, which aesthetically would drive me bananas.
A minor problem for a practical solution, for me.
- travsbluz
I don't have one of these to try this, but...
You said that when you mount them with the adhesive, THEN put the battery in, the adhesive pops free. How about putting the battery in the clip first so the clip is in the shape it would be in, then mount with the adhesive.
I'm really thinking out loud this may not work either
Don't use batteries?
Anyway, before I stopped using batteries in pedals (which is better for the environment, saves space, and requires less upkeep), I just held them in place with good old duct tape. It worked well.
"How come they don't fly away?"
- soulsonic
I did this using "J.B. Stick" epoxy putty, and it worked pretty well. After it was cured, everything was fine. You also want to rough up the metal parts that are going to be glued with some coarse sandpaper.travsbluz wrote:I don't have one of these to try this, but...
I've been velcroing everything lately - PCB, battery clip, wires etc, so far so good, nothing has fallen off yet after a couple of weeks of use.Zokk wrote:So, what about using some velcro grip under the battery holder?
Velcro will keep the battery clip in place, regardless of the bend.
EDIT: Oh yeah, first post, after months and months of lurking =)
