Wampler Sovereign Distortion  [traced]
lukatosh
Has thanked: 33 times
Been thanked: 180 times
Post by lukatosh »
this was supposed to be posted here... sorry :( ...
just couldn't delete the topic posted in modern effects
anyway...have you seen this?
it sounds just great!
from wampler website:
It has a mid control that is admittedly borrowed from other great Wampler pedals like The Pinnacle, but this one is refined, less fussy and instantly gratifying over the full range of its sweep
Check this out...From youtube...5 transistors (maybe j20, used often), power mosfet for polarity protection, and a JRC4580D... no onboard pots names/values :cry:
jymaze
Has thanked: 86 times
Been thanked: 167 times
Post by jymaze »
It looks like a BMP tone stack with a variable mid pot (see MI Audio Tube-Zone for an example).
jymaze
Post by jymaze »
So my best guess is:
- 4 cascaded JFET gain stages, the 5th being a buffer before the tone stack(see Dr Boogey)
- a BMP tone stack with variable mid pot (see Tube Zone)
- an output opamp buffer to recover the loss of amplitude (see Pinnacle II LE)
- the bright switch would add a bright cap somewhere around the gain pot (think Marshall amp)
- the boost switch changes the voltage dividing network between stage 2 and 3 (probably)
I have been thinking about making a Dr Boogey with a BMP tone stack with mid control for a long time. It seems I was not the only one.
culturejam
Has thanked: 450 times
Been thanked: 552 times
Post by culturejam »
Is that an opto isolator IC at the top of the board (4 pins)?
lukatosh
Post by lukatosh »
from wampler tweed 57 topic...
Actually it is the polarity protection. Read this article by R. G. Keen. The advantage of this method is the very low voltage loss across it, as opposed to usual series diode which eats around 0.6V.
okgb
Has thanked: 190 times
Been thanked: 30 times
Post by okgb »
What does the name suggest ? ??
Ice-9
Completed builds
Far to many to afford the enclosures for them all. :)
Has thanked: 131 times
Been thanked: 350 times
Post by Ice-9 »
culturejam wrote:Is that an opto isolator IC at the top of the board (4 pins)?
It's more likely a fet for polarity protection (diode next to it as well.)
OOps someone already said this. :slap:
indyguitarist
Been thanked: 142 times
Post by indyguitarist »
jymaze wrote:So my best guess is:
nope! ;)
jymaze
Post by jymaze »
Thank you for the dream-crushing Mr Wampler... :wink:
Maybe mu-amps then...
lukatosh
Post by lukatosh »
up!
mrkaploca
Has thanked: 15 times
Been thanked: 12 times
Post by mrkaploca »
jymaze wrote: Maybe mu-amps then...
Most certainly, judging by the amount of gain available...
thn.technik
my favorite amplifier: Laney
Completed builds
Shred master, Tube screamer, Reezafratzitz, SansAmp GT2, RAT, Okko Diablo, Metal Simplex...
Been thanked: 43 times
Post by thn.technik »
any news? somebody have this pedal? maybe some pics for trace ;-)
Mrdorbe
Post by Mrdorbe »
i'm really interested in building one on my own.. did anyone trace this circuit or made a layout? thank you.
Nacho5
Been thanked: 5 times
Post by Nacho5 »
I'm very interested in build one. Did anyone trace this circuit or made a layout? thank you.
Has thanked: 3460 times
Been thanked: 724 times
this:
wampler souvereign gut shot
roseblood11
Has thanked: 344 times
Been thanked: 298 times
Post by roseblood11 »
It would be really interesting to see this pedal retraced!
It started with a limited run for musiciansfriend, but it's easily available now.
Bloodman
Has thanked: 13 times
Been thanked: 41 times
Post by Bloodman »
The monolithic circuit and parameters of the sovereign are very similar with the pinnacle
MoonWatcher
Has thanked: 41 times
Post by MoonWatcher »
Bloodman wrote:The monolithic circuit and parameters of the sovereign are very similar with the pinnacle
Indeed. It seems that there are a bit of similarities, in particular, with it and the Pinnacle LE. The latter was traced out in what I think was a Pinnacle II thread. So I went and dropped in the capacitor values for the LE, and then looked at the Sovereign. I tried to label what I thought might be the cap equivalents.
I figured that until someone has one to trace, that the next step would be figuring out the resistor values, and then they could be cross-referenced to the Pinnacle as well.
This seemed like as good a place as any to start. I hope it helps.
Pinnacle LE - cap values added
Sovereign - speculated cap values added
Bloodman
Post by Bloodman »
I have already traced this pedal
Ice-9
Completed builds
Post by Ice-9 »
Smashing, I couldn't be happier for you. Thanks for sharing.
