Moen Holy Choir Chorus [guts shots]
Postby pedalgrinder » 28 Jun 2012, 08:35
Hi everyone here is some guts shots of the moen holy choir chorus. I know that a lot of these pedals are copys of a schematic out there that is another pedal for instance the moen unicomp is a diamond compressor the moen shaky jimi is a john hollis easyvibe so basically i would like it if anyone could verify by the guts shots what this one has been copied from. It hasn't become apparent to me. But if anyone can tell i would love to hear from you. Hope you enjoy the guts shots! :thumbsup :thumbsup :thumbsup :applause: :applause: :applause:
For this message the author pedalgrinder has received thanks: 5
atreidesheir (28 Jun 2012, 16:17), IvIark (28 Jun 2012, 08:57), rocklander (28 Jun 2012, 08:42), roseblood11 (29 Jun 2012, 23:06), twangster (11 Sep 2012, 00:09)
pedalgrinder
Has thanked: 203 times
Have thanks: 154 times
Re: Moen Holy Choir Chorus [guts shots]
Postby pedalgrinder » 28 Jun 2012, 08:39
and a few more
For this message the author pedalgrinder has received thanks: 2
atreidesheir (28 Jun 2012, 16:17), rocklander (28 Jun 2012, 08:43)
pedalgrinder
Postby pedalgrinder » 29 Jun 2012, 14:48
theres and ic on this board with this written on it: 022D JRC 4031A does anyone know what the hell it is. At a punt iam assuming just an op amp but if anyone could shed some light on that it would be helpful cheers :thumbsup
pedalgrinder
Postby marmaliser » 29 Jun 2012, 14:57
marmaliser
Has thanked: 56 times
Have thanks: 48 times
Postby pedalgrinder » 29 Jun 2012, 15:35
yeah good on you if a datasheet had come up in a google search i would not have posted the question there is no datasheet that i have found. Thats why i asked i don't need directions on how to use google.
pedalgrinder
Postby roseblood11 » 29 Jun 2012, 23:08
jrc version of a tl022, I guess. Maybe you can see from the connections if it's a standard dual opamp?
roseblood11
Has thanked: 356 times
Have thanks: 325 times
Postby IvIark » 29 Jun 2012, 23:44
I'm really impressed with that for the price. Wasn't expecting an MN3007/3101
IvIark
Has thanked: 668 times
Have thanks: 685 times
Postby pedalgrinder » 30 Jun 2012, 00:12
yeah i've had a good look at a lot of the cheap pedals and moen generally wins on build and through ease of getting apart and modding hands down every time. I like there pedals for the price and easy to mod to turn into so called boutique. they are also allready true bypass. I am not trying to put an advert up i just reckon for someone who wants to tweak an exisiting pedal for the price these are the go.
pedalgrinder
Postby IvIark » 30 Jun 2012, 00:20
My Moen encounters have been positive too. I've got the MO-FM Fuzz Moo and it is a really good sounding muff, in fact one of the best sounding muffs I've played. In fact that's a good point, I could do with opening it up and seeing what's in there.
IvIark
Postby atreidesheir » 30 Jun 2012, 01:07
I love hearing something reasonably priced is good quality. What is the verdict on the Holy Choir. Is it worth owning?
atreidesheir
Has thanked: 452 times
Have thanks: 43 times
Postby pedalgrinder » 30 Jun 2012, 09:12
yeah it's not bad as is but iam going to mod the hell out of mine. First thing is to pull out those horrid jrc4558 i hate those op amps all there good for is a tube screamer. put some nice lf353's in well i like them. Taste on op amps is another whole fiasco in itself. the other thing i will do is look for any shit electrolytics and replace them if there anywhere near the signal path. other than that may play with the oscillation speed and look putting a volume control if needed. But some of that stuff will be only if i think it needs it.
pedalgrinder
Postby guycapuano » 30 Jun 2012, 13:57
IvIark wrote:I'm really impressed with that for the price. Wasn't expecting an MN3007/3101
ME TOO :thumbsup
guycapuano
Has thanked: 32 times
Have thanks: 10 times
Postby pedalgrinder » 05 Jul 2012, 12:35
I reckon from a fair bit of study of the board on this one that's it's pretty damn close to a boss ce-2 need follow it with a fine tooth comb to see the main difference's correct me if iam wrong but it seems that way. a change to fet op amps would give it that warmer sound that a chorus should have. why oh why would they use those shitty jrc4558's you need your head read if you use them in a chorus.
pedalgrinder
Users browsing this forum: Google Feedfetcher, MSN [Bot] and 4 guests
