Vox / Orange / Apollo - Treble and Bass Booster [schematic]
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
shit, values were missing
again...
again...
Here is my take on the Vox treble and bass booster. I used Gottfried Divos' schematic. I wanted to make a layout with no cuts...
As yet unverified, once I set my workshop up again in Alaska I'll build it up.
- Vox- Treble and Bass booster.jpg (40.88 KiB) Viewed 3051 times
I forgot to add input via T/B: lug 2.
Thanks Pedalman85 for sharing your schematic - I built it and it works like a charm.
I too tried building from one of the other Apollo boost schems on the web and it was obvious something was seriously wrong. I figured it might have been the base and collector loads at fault but wasn't sure.
Great work. Many thanks!!!
- Harold
@Pedalman85: thanks for the schematic! Did you build a clone yourself?Pedalman85 wrote:soooo sorry folks! forgot pw and forgot that i made this enjoy. Note: S1 and S2 is a DPDT slide switch.
I don't have any 2SB175's at hand, so I will try a AC128 first ...
DIY-Layout.com: Online stripboard layouts
Harold wrote:@Pedalman85: thanks for the schematic! Did you build a clone yourself?Pedalman85 wrote:soooo sorry folks! forgot pw and forgot that i made this enjoy. Note: S1 and S2 is a DPDT slide switch.
No I haven't been able to find 2SB175's and I've been preoccupied with a PT2399 based delay pedal build/design as well as a load of other projects. I did find some 2SB176's not sure if they would sound the same but I'm going to give them a try once I get a order together.
Best of luck with cloning it! I'm sure some of the part will need to be substituted (like the caps) but most of the closest values should be with in tolorences.
I'd say if ya do build one, slap a 1M pulldown resistor on the input (soldered between the signal and ground of the input Jack) to tame the pop when it's turned on. Some power supply filtering/protection would be a bad idea either.
- Harold
Well, I already created this layout for it:Pedalman85 wrote:I'd say if ya do build one, slap a 1M pulldown resistor on the input (soldered between the signal and ground of the input Jack) to tame the pop when it's turned on. Some power supply filtering/protection would be a bad idea either.
Apollo treble bass booster
... I guess some filtering could harm either ...
- Harold
Hmmm... "You cannot edit your posts in this forum"
I meant to say: some filtering couldn't do any harm. And the link to the layout: http://diy-layout.com/76
Very nice layout, it even looks like it might be about the same size board as in the original.
I personally have never used a strip board for projects (mostly perf or multipurpose) but I might have try my clone like your layout.
A couple of mods I thought of were replacing the output pulldown resistor with a pot for volume control or maybe replace the resistor in the tone stack with a pot (and maybe a fixed resistor in series) for a sort of scoop/timbre control. And of course there are endless combos for the caps in the tone stack. Idk just some ideas
- Harold
You mean that the current pot is for treble or bass and not for volume?Pedalman85 wrote:A couple of mods I thought of were replacing the output pulldown resistor with a pot for volume control
- LucifersTrip
- my favorite amplifier: Companion Psychedelic Machine
- Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
- Has thanked: 19 times
- Been thanked: 71 times
- Contact:
- Harold
Ah, found an error in my layout which sent the bass side straight to GND
Fixed the layout: I now have a bass or treble booster! Well "booster" isn't the correct term as it has a volume drop.
alright folks i've finally got some 2sb175's to try to clone the Apollo booster. btw small bear is currently carrying them as well as 2sb176's. so i had to sub in 2200pf, 33uf, 4.7uf caps and a 33k resistor. the original 2sb175 had an A labeling for it's Hfe range and the ones from small bear are all B's. they come in at about 270-400 Hfe, much higher then the datasheet says they should be but oh well.
So as Harold put it's not quite boosting as it's name would imply. Here's the problem!!! I A/B the breadboarded with the original and the original has a noticeable boost and the breadboarded clone has a drop!
As far as i can tell all the voltages are close to a match with the original. The original draws about 480uA while the breadboarded depending on the transistor is any where from 307uA-900uA.
i've even tried sb176's in it and was pleasently surprised at how much less hiss was present.
I have messed with different values in the voltage divider and both the collector and emitter pins but i haven't noticed much change.
so my questions to you fine people are: would i only need to change the 10k resistor on the collector to bias? and is there any possable way to measure or rough guess what the original transistors Hfe is without removing it from the circuit?
