Kay - Fuzztone (F-1)  [schematic]
Re: Kay - Fuzztone (F-1)
Postby Fastnet » 17 Nov 2012, 09:09
Morning all,
Seen this tread has become active again...
All is well with my build so many thanks again to all who made it happen.
Just one question, is it possible to boost the ouput and bring the pedal up to unity gain or perhaps even slightly above?
I'm aware the actual design isn't an "award winning" version but as my first all singing, all farting fuzz I'd like to persevere. ..
Kind regards to all as usual,
J.
"After silence, that which comes nearest to expressing the inexpressible is music." Aldous Huxley
or...
"Pog mo thoin!"
Fastnet
Have thanks: 7 times
Postby mictester » 13 Feb 2013, 23:15
analogguru wrote:This has been discussed to a "dead horse" at the other forum ages ago. Google is your friend - you only have to use it:
http://www.diystompboxes.com/smfforum/i ... ic=55883.0
http://johannburkard.de/blog/music/effe ... -Tone.html
Therefore I don´t understand, why there always doubts come up.
BTW, The Kay Fuzz Tone is the poor man´s version of the Univox Super Fuzz, and later the Ibanez Standard Fuzz:
http://analogguru.an.ohost.de/193/schem ... rdFuzz.gif
Maybe the Ibanez Standard Fuzz will fit your taste better.
Messing around with some Vero and Little Lance's "Fuzz IC", I threw together a Kay / Ibanez. It's not the smallest Vero layout, but it works. The octave is really pronounced (because of the great balance of the long-tailed pair in the IC). I selected the bias resistors for the long-tailed pair from the ones I had in the drawer the 150k and 22k resistors were selected to match.
Sounds great! This has persuaded me to design a PCB for it!
For this message the author mictester has received thanks: 5
jrod (14 Feb 2013, 06:33), Mbas974 (26 Feb 2013, 00:03), Mich P (14 Feb 2013, 13:01), roseblood11 (13 Feb 2013, 23:29), telecaster (14 Feb 2013, 03:37)
mictester
Has thanked: 33 times
Have thanks: 826 times
Postby mictester » 14 Feb 2013, 23:01
As promised: The PCB. Built three of these in the last few days, and they sound really great. It's worth choosing the 150k and 22k bias resistors for the long-tailed pair. I found a pair of 148k7 for the first one, another had a pair of 151k and so on. If you have a bag of (say) 20 resistors, you should be able to find two that are identical. It really is worth the effort - the better balanced the transistors are, the more doubling you'll hear!
Experiment with the tone "voice" filter - one player liked the 1n increased to 3n3, another wanted 1n5. I put the 1n in the board, then solder a padding capacitor across the terminals under the board!
There are interesting sounds available with the "Drive" turned down and the "Level" advanced. If you use the "straight", unfiltered "Voice", you can get some very subtle colouration that sounds like a Fender amp just on the verge of going into distortion. My Country-playing friend really likes using it this way.
Other modifications - the "Voice" switch I use is a DPDT, with the second pole used to drive a bi-colour LED to indicate mode. I've used the ultra-low current relay driver for silent, true bypass. I also added a muting transistor across the "Drive" pot, driven by the relay switching circuit, so that there wasn't any chance of breakthrough in "Bypass" mode.
Using the CA3046 is a pretty good emulation of the old, lower gain silicon transistors that were used in the 1970s. People mostly didn't take the Kay pedal seriously because it was in a cheap, brightly-coloured plastic box, and was sneered at as a toy by serious guitarists. They didn't know what they were missing!
Track Side:
This pedal sips current from a 9V battery, and really does sound great. If GGG or GuitarPCB want to make this board, please go ahead. It works and sounds great!
telecaster (15 Feb 2013, 05:37)
mictester
Postby mictester » 14 Feb 2013, 23:05
One thing I forgot - use any Germanium diodes (or the base-emitter junction of a low gain germanium transistor). If you want a louder, more aggressive sound, use Schottky or silicon diodes. Silicon will be outrageously loud, and will cause the last stage to distort too, which (to my ears) sounds horrible, but you can try it if you want.
This pedal really cuts through in a band situation, and it has some great sounds available!
mictester
Postby Chugs » 25 Feb 2013, 14:35
Looks cool Mictester. I have played around a bit with the Kay circuit myself. Do you have a schematic of your version?
Chugs
Has thanked: 65 times
Have thanks: 51 times
Postby Mbas974 » 26 Feb 2013, 00:09
Michester,
from your experience what is the best MOD to get the U2-Elevetion sound with this new circuit ?
The voice switch is supposed to be the hot potz ...is it right ?
Schematic wil be appreciate as well tx
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Postby Fastnet » 14 Mar 2013, 12:47
Mbas974 wrote:Michester,
Hi Mbas,
Although he's famous for exotic and rare pieces of kit, I've read that he was first introduced to the Kay by Danny Lanois and the rest as they say is history!
So for that reason, I would have thought that Edge's unit was just "reinforced" to stand up to the rigors of touring and therefore assume that his would be true to the original... my build sounds very close but you can't ignore that some processing will have been added during the mixing and mastering of the studio take.
Have a look at this, it might point you in the right direction...
[youtube]http://www.youtube.com/watch?v=eeupLXuoWko&list=FLv3CIbczjZT1mDbwixHCd7A[/youtube]
Do fancy following the latest rendition by Mictester when I get time... thanks for some late nights of frustration in advance!
J.
or...
"Pog mo thoin!"
Fastnet
Postby Mbas974 » 14 Mar 2013, 13:01
Tx Fastnet, I've already built a couple of KayFuzz clone circuit using BossGBC95 enclosure using original schem.
....Edge FX chains both live and studio is well know :-))
What I was asking is a "smart/fast way" to get close to... with the new Op-amp circuit.
But since I can't get the replay, I will test it on board by myself.
Mbas974
Postby Fastnet » 14 Mar 2013, 13:06
No trouble fella,
Keep us posted with the results...
J.
or...
"Pog mo thoin!"
Fastnet
Postby Bernardduur » 01 Dec 2014, 11:57
sinner wrote:Ok, I almost search of my ass to find this pict of the pot. Factory schemo is wrong as you clearly see. K-fuzz pot is not 50k, it's actually 250k so AM schemo is right here
The schematic is quite all right; the factory potmeter is 250k, B, but in this pedal the potmeter is only used for a small amount of travel.
If the travel of the potmeter by the threadle was max then you should use a 50k potmeter with a 200k resistor to ground
The travel of the threadle in the Kay is very minimal. It only uses 50k of the 250k potmeter, the restant (200k) is left to ground as drawn in the schematic.
Bernardduur
Has thanked: 87 times
Have thanks: 506 times
Postby theyear2042 » 15 May 2015, 09:52
hey guys
i just built this with 2n5088 Q1/2 and 2n3904 Q3/4
i'm getting quite a lot of gating on low volume notes. sounds great then when the note rings out it gates to silence really quickly.
im thinking its trannies not biased properly.
do other people have this problem? if not, can you let me know the hfe of the trannies. ive read some people say 500 - 600hfe for the kay fuzztone, where i my 2n3904's are reading 180hfe.
theyear2042
Postby theyear2042 » 16 May 2015, 02:34
sorted my problem - used a 100k bias resistor where i should have used a 10k. damn.
still gates a little bit but no where near as much. pretty cool effect.
theyear2042
Postby johnk » 21 Jun 2015, 22:40
I uilt mictester's CA3046 version. shoukld I assume that the unmarked resistor directly below the CA3046 is a 510K as shown by the color bands?.
johnk
Have thanks: 277 times
Postby francis1978 » 25 Jan 2016, 04:39
I hope this thread is still open,
well I've or tempted, should I say, to build a kay fuzz clone. Everything seems perfect except for the low volume and no fuzz; although I can hear the octave. What it's more strange is that I can only hear when I select the middle pickup of my guitar... the bridge and neck are very faint. I had to desolder all elements including the jacks and switch as the early attempts were giving no results. Now the jacks and pot are connected string to the board which in turn is connected to my GT-10 (I will test it on my amp next week). However, this shouldn't prevent me to hear the fuzz.
Using pictures of the original board I was able to recreate the layout and this mine has been built in the same way. I used BC548 instead of 2SC644S and 2SC828 (as per original) and the diodes are 1N34A.
Transistors (Qs) read:
Q1 Q2 Q3/4
E 0.25 2.39 0.26
B 0.80 2.85 0.81
C 2.74 4.64 7.60
For diodes, well when I connect the multimeter leads (at Volt), there are no reading.. but they test 294 and 301 so I guess these in the voltage drop ranges..
I am wondering, what have gone wrong??
I used the tranbaland schematics which has the 2n2f cap at correct the position (compare the original board).
Any ideas??
Is driving me nuts
thanks
francis1978
Postby Mbas974 » 25 Jan 2016, 22:46
If you are attemping to reach The edge tone better using 2SC945 (as the original unit use...),
but you should reach a good fuzz too using any other TRX.
low volume.... did you double check the pinout of used TRX ?
For this message the author Mbas974 has received thanks:
francis1978 (25 Jan 2016, 23:45)
Mbas974
Postby francis1978 » 25 Jan 2016, 23:54
First thing first, sorry for the typos.. it was late when I wrote the message and was unable to recall it to edit.
Mbas974.. thanks for the prompt reply.. yes it is working.. I did have the pinouts of the TRX soldered correctly.. the mistakes were:
1. negative 9+v snap was not connected to ground; and
2. in/out jack were going to ground, so when I removed and connected together alleluia!!!! .. I guess I was blinded by frustration :evil:
Now the only thing left is the swell .. I was trying with a linear pot but I have a log one so I will swap it and check it again.. but at least the fuzz is working and its bloody loud!! :lol:
Again, as the original board, I have not connected the 100K resistor from output to ground so will see :mrgreen:
Mbas974 wrote:If you are attemping to reach The edge tone better using 2SC945 (as the original unit use...),
francis1978
Postby Fastnet » 27 Jan 2016, 11:47
Just a little update, finally sat down and swopped out the germaniums for some 1N4148's and it is outrageously loud!
It pushes my VOX much harder and doesn't loose that much of the octave either which I was quite surprised about... cant say what sounds better just a very handy boost which has made this less of a one trick pony as I'm using it for some solo's as well.
or...
"Pog mo thoin!"
Fastnet
Postby francis1978 » 03 Feb 2016, 04:24
Ok now I'm getting frustrated...
The board is working, fuzz is great but there is no tone at all. The pot acts more like a volume control... no bass/treble when rolled back/forward. I'm getting annoyed...
I have attached my traces with the original and my own board which is the big one on the draw. Can anyone see what the hell did I do wrong??
Thanks.
francis1978
Postby francis1978 » 04 Feb 2016, 06:20
Problem solved!!!! :applause:
The pedal is working. Thank you all for letting me vent!
francis1978
Users browsing this forum: Dr Tony Balls, sledziowy and 2 guests
