Zvex - Probe series
tangalanga
Post by tangalanga »
Hi All!
thanks for all the information,i built this on perf and it worked ok,except that i have "reverse response",the led has max brightness when my hand is far from it,i'll check which pin of the 4093 i used as an output :-P
I plan to use it as an expression pedal for my old and loved lexicon vortex...
Thanks again! :D
~arph
Has thanked: 60 times
Been thanked: 163 times
Post by ~arph »
Hi, yes you're probably getting the output on on of the earlier inverters in the chain. Should be easy to find/fix.
Regards,
~arph
tangalanga
Thanks! i'm using your traced schem,arph...i checked the output signal with oscilloscope,it's a variable rate square wave,i'll check the pins later when i'm back at my workshop...i'm reading the rock and control article,really exciting posibilities...
I'm also planning to build a theremin,now that i saw that this is a stable method of control (previously i supposed it would be impossible to trim/calibrate)...
humm...delay time control..."ECHO PROBE"? :twisted:
ech0es
Post by ech0es »
Now imagine a SEEK PROBE, with a probe control in addition to EACH pot of the sequencer. :twisted:
~arph
Post by ~arph »
tangalanga wrote:Thanks! i'm using your traced schem,arph...i checked the output signal with oscilloscope,it's a variable rate square wave,i'll check the pins later when i'm back at my workshop.
Flip the LED.. In my schem the LED is oriented incorrect. That's why you probalbly get inverted PWM response.
~arph
Post by ~arph »
ech0es wrote:Now imagine a SEEK PROBE, with a probe control in addition to EACH pot of the sequencer. :twisted:
One probe and S/H surely?
tangalanga
Flip the LED.. In my schem the LED is oriented incorrect. That's why you probalbly get inverted PWM response.[/quote]
I don´t think it´s a led polarity problem ... cathode must be conected to ground,and positive comes from the the transistor (anode)
~arph
Post by ~arph »
Mmm.. yeah.. you're right, cant think clearly when at work..
then the pulses must be inverted than I guess. So you either tap at the wrong inverter or you have to add one.
xaxxop
my favorite amplifier: Gallien Krueger 400RB
Completed builds: DIY: Boss ce-2, EH big muff, MXR microamp, DOD FX25, Stingray Preamp
Post by xaxxop »
Very good work!!!!!
The project of the wahprobe exists, I cannot find it, thank you very much I wait for response!!!!!
Leandro
tomassio22
Post by tomassio22 »
So can any on here make a clone of the zvex wah probe? Or a probe circuit that I can hook up to a fuzz factory to make it a fuzz probe? I would be very interested in that. Someone, anyone, please let me know!!!
Jaicen
Post by Jaicen »
tomassio22 wrote:So can any on here make a clone of the zvex wah probe? Or a probe circuit that I can hook up to a fuzz factory to make it a fuzz probe? I would be very interested in that. Someone, anyone, please let me know!!!
I guess you didn't bother reading this thread all the way through before posting then?? The answers are all there if you look...
DWBH
Post by DWBH »
For a Wah Probe, use the Colorsound Inductorless Wah, and replace the Sweep pot with the LDR.
For a Fuzz Probe, put the LDR in parallel with the Stab pot.
tomassio22
Nope, I read every single post last night, I'm just a bit intimidated about making one, and I'm short on spare time. So I'm asking if I can pay anyone on here to make me one, just to start me off, something to look at and learn from, I don't have any formal training in electronics, so it would just be a help to me, i could give you $50 or something to show my appreciation. If I can't find anyone, I will just try myself.
If it comes to that, any one stop place to buy everything needed? Thanks
Jaicen
Post by Jaicen »
Ah, I see! Sorry, I guess I didn't read your post properly (i'd been up for 36hrs straight).
To be honest, i'm not entirely sure of the rules here regarding building clones for other people. Ethics is a grey area for sure, but I think you'd learn a great deal building one yourself. I've built probes before, they're not a difficult build at all, provided you take the time to calibrate it properly. My advice is to get multi-turn trimpots for the adjustments, and use a fresh battery or well regulated power supply. If you use a battery, bear in mind that it will affect the adjustment when you house it, through capacitance with the case, so final adjustments must be done in-situ.
tomassio22
No problem, I can see how you read it. More importantly, get some sleep! Jeez!
I guess I will make the time to make one myself. If anyone could help me find the parts, that'd be really cool. I've searched ebay with little success. Where do you get these things?!
And thanks for the tips J, i'll keep them in mind.
Jaicen
Post by Jaicen »
Sleep? Nah, that's for sleepy people ;) Haha.
Seriously though, the components are real run of the mill stuff. In the UK you can get them from Maplin, RS components or Rapid Electronics.
In the US, I'd guess Futurelec, or Digikey would be your best bet. Ebay is not really the place to be looking for stuff like that to be honest.
~arph
Post by ~arph »
also,
Mouser
smallbearelec
tomassio22
yea, i find that some common switches are cheaper on ebay, but most small electronics stuff like what i need isn't there. thanks for those sites, both of you guys.
Jaicen
Post by Jaicen »
I second the SmallBear stuff. Steve Daniels is a top bloke, hell supply you with a set of matched AC128's that will sound killer in the FF.
littleBloona
Post by littleBloona »
visual audio wowmeeowgutzzz
