[Tips & Tricks] Perfboard Building
drmathprog
Post by drmathprog »
I'm inspired by the Eternity and King of Tone perfboard projects. Can someone point me to a tutorial or suggest techniques for soldering a perfboard project? Specifically, I'm not clear on how I can solder the components on one side to the wires on the other side.
ieatyouforbreakfast
Post by ieatyouforbreakfast »
don't cut the leads to the components and use the extra lengths as traces.
drmathprog
Thanks. Seems obvious, but it didn't occur to me until I read your post. :D
Dave Simpson
Post by Dave Simpson »
drmathprog
That's perfect; I don't know why I couldn't find it! Thanks!
Alex C
Post by Alex C »
The Tweak-O project has hole-by hole instructions, and shows both sides of the board at several stages. It was my first build, and I was very fortunate to have this project as a guide.
-Alex
ubersam
Been thanked: 7 times
Post by ubersam »
I create a layout for a pcb then use that as a guide when building on perfboard.
drmathprog
Thanks Alex. I've never seen those push in terminal posts before. Where did you find those?
Alex C
Post by Alex C »
drmathprog wrote:Thanks Alex. I've never seen those push in terminal posts before. Where did you find those?
Steve at Small Bear Electronics (who created the Tweak-O tutorial) calls them "flea clips" and sells them on his site here.
