Hinged Pedal Enclosures
Postby Rixen » 14 Sep 2013, 09:32
I would like to introduce a new enclosure:
http://www.rixenpedals.com
The Rixen effects pedal enclosure is designed specifically for enthusiast or professional effects pedal builders.
Features solid die-cast aluminium construction, large hinged pedal (activating a 4PDT switch with gold plated contacts for true bypass) and integral battery compartment (accessible from the top, and without using tools ! ).
Kit includes:
1x 4PDT latching switch, gold contacts
1x Body
1x Pedal
1x Bottom Cover
4x Feet
1x Pedal Pad
1x Spring
14 x Metric 3mm x 5mm screws (Zinc plated steel, Pan-pozi) (Includes one spare screw)
2x Small neoprene foam pads to cushion pedal motion
2x Large neoprene foam pads to secure battery
1x Holdback clip (holds pedal closed)
2x High tensile steel hinge pins (hinge component, fitted to pedal)
2x Nylon bushes (hinge component, fitted to body)
Length: 139.5 mm ( ~5.5" )
Width: 89.5 mm ( ~3.52" )
Height: 69 mm ( ~2.72" )
(Boss Pedal = 125.5mm x 70mm x 55.5mm)
- PCB mounting bosses for two layers of circuit board
- Dimpled hole centres for fast, accurate drilling of holes for front panel components. (6mm centres, with one extra column dead centre)
For this message the author Rixen has received thanks: 2
JudgeMingus (17 Sep 2013, 02:30), rocklander (13 May 2015, 02:21)
Rixen
Have thanks: 2 times
Re: Hinged Pedal Enclosures
Postby rocklander » 15 Sep 2013, 12:07
welcome to the forum rixen.. I think you'd get a lot more interest here if you posted the internal shots I saw over at six string samurai.. the mounting posts and switching mechanism were pretty damn cool.. that's the sorta shit that fsb doods love.. smart engineering.
:thumbsup
For this message the author rocklander has received thanks:
Rixen (16 Sep 2013, 21:53)
rocklander
Has thanked: 1582 times
Have thanks: 290 times
Postby mictester » 15 Sep 2013, 13:21
Nice boxes, but about 8X what I pay for diecast boxes. Shipping to Europe is also extortionate. They're also rather small inside.....
I'll stick with my powder-coated Hammond and Eddystone boxes.
mictester
Has thanked: 33 times
Have thanks: 824 times
Postby Nocentelli » 15 Sep 2013, 13:49
Very cool idea, really nice looking execution, but I can't help think mic is right about the price. I can see how this is neccessary to make it profitable whilst recouping investment and allowing for the predicted (relatively slow) rate of sale, but I would only be able to justify splashing out on one of these for a personal-use pedal where I didn't care about the cost, or if someone was paying me silly money for a one-off build. I can't really see how commercial pedal builders could buy these unless there's a hefty discount for bulk.
Rixen (16 Sep 2013, 21:55)
Nocentelli
Has thanked: 914 times
Have thanks: 864 times
Postby Rixen » 16 Sep 2013, 21:45
Thanks Rocklander, here's the internal shots you mention, and the battery access.
The hole centres you can see in the vid mean you can drill accurate front panel holes, no marking out, with an electric hand drill (pilot hole is a good idea though)..
These are pretty rough videos, but they demonstrate that this is more than a simple box..
Rixen
Postby JudgeMingus » 17 Sep 2013, 02:36
Your enclosures look brilliant, and you have obviously put a lot of thought into the design!
Like most posters so far, I am not sure I can justify spending so much for an enclosure and switch when I would normally get both for $10 - $15, but the cost does seem justified for such a complex item in low volumes.
If I were doing volume production, and you provide volume discount, it might be a different story.
I might recommend one of these to the client when doing a custom build, too - especially for someone who tends to stamp all over their pedals and damage knobs etc on standard rectangular boxes.
For this message the author JudgeMingus has received thanks:
Rixen (17 Sep 2013, 12:36)
JudgeMingus
Has thanked: 36 times
Have thanks: 7 times
Postby Dirk_Hendrik » 17 Sep 2013, 07:04
Mictester and Nocentelli bring up the matter that was my first thought as well. While it may be something Rixen can't do too much about w.o. losing money the arguments are still valid. Therefore the way of responding to critical questions , (not), alone is a reason not to opt for these boxes.
However,
I'm very interested in the boxes Mictester uses. The fact that he pays some 5usd for a box is nice for him but I have a hard time believing these are in any way comparable to the boxes Rixen posts here. Like comparing a Fiat to a Mercedes.
Has thanked: 255 times
Have thanks: 1044 times
Postby rocklander » 17 Sep 2013, 08:13
I agree on all counts.. I'm in NZ and still am too much a cheap bugger to invest in one of these, but I also can appreciate the engineering.. they're bloody cool boxes.
wrt the extortionate prices for shipping to europe... you're quite correct. the price is outrageous.. and the price we pay from NZ. srsly.. it's insanely expensive to use any of the available shipping options ex NZ.
I'm consistently astonished at how cheap shipping from the UK (and on top of that how lightning fast it is) via royal mail when I buy guff off ebay.. it's just second to none.
I recently purchased a laptop at a local store. they had none of the model I bought in store so they had to get one in from a store in another town (1.5 hour drive). the next day I bought a laptop stand off ebay.
the laptop stand managed to go from UK (birmingham to london) to NZ (auckland, then rotorua - 3.5 hours apart) to my work faster than the laptop could from the store 1.5 hours away.
we get SO shafted wrt shipping in NZ. :x
rocklander
Postby Nocentelli » 17 Sep 2013, 09:55
rocklander wrote:I'm consistently astonished at how cheap shipping from the UK (and on top of that how lightning fast it is) via royal mail when I buy guff off ebay.. it's just second to none.
[offtopic] here in the UK, the govt has just confirmed they are going to sell-off the Royal Mail - I imagine the service will be even better when it's privatised :roll: [/offtopic]
http://www.telegraph.co.uk/news/uknews/ ... weeks.html
Nocentelli
Postby Rixen » 17 Sep 2013, 12:27
Yes Dirk_Hendrick, there is not much reduction in price that can be done before losing money.
I made the decision to have them made locally in New Zealand, rather than outsourcing to a low labour cost / low environmental compliance country where I would have little control over quality issues.
The shipping is charged at cost, I can ship via surface which is $ 1 to $ 2 cheaper, but 4 weeks longer (!) :shock:
Those interested in more than 5 enclosures can expect to obtain a 10% discount, and reduced shipping.
I hope to have 6 and 12 pack size pricing up on the website soon.
Rixen
Postby Dr Tony Balls » 17 Sep 2013, 14:10
Dirk_Hendrik wrote:However,
There's quality comparison issue to be had where mictester is probably talking about an unpainted Hammond box, where Rixen's stuff is painted. Looking it up, and not counting volume discount, i see that PPP sells an finished 1590BB for $11.45 so the price difference is then ~4X. If I remember right, though, ive seen mictester underestimate the cost of parts before when making a point.
For this message the author Dr Tony Balls has received thanks:
Rixen (17 Sep 2013, 21:15)
Dr Tony Balls
Have thanks: 157 times
Postby phibes » 17 Sep 2013, 15:22
Awesome job Rixen! These are cool!
The price is right on these, everybody's just being a cheap bastard. You can't really compare these to Hammonds and the ultimate biggest pile of shit New Sensor boxes. :roll: Not every DIY build has to be done for lowest cost possible.
Image Ken
For this message the author phibes has received thanks:
Rixen (17 Sep 2013, 21:14)
phibes
Has thanked: 85 times
Have thanks: 188 times
Postby soulsonic » 16 Nov 2013, 07:47
I'm going to agree with Phibes on this one. Price is reasonable for DIY personal builds for fun. Box + guts will probably still be less than the usual Boss pedal and way less than a bootweek swirly paint pedal in a junk NSC box, so why complain?
Oh, the high price cuts into your resale profit margin. Boo-hoo! :roll:
Has thanked: 73 times
Have thanks: 296 times
Postby sinner » 17 Nov 2013, 00:25
Cute
Has thanked: 1240 times
Have thanks: 1100 times
Postby sinner » 17 Nov 2013, 00:43
BTW, I was trying to start making MKII Professional enclosures ones, and the price for the form killed my dreams instantly. These (the injection molding forms) are expensive, the costing is just insane, so I do understand the price
These are green :) Good internal attention to detail as well, I was amazed with Chris's wiring skills - also how friendly in personal contact Chris is
Postby Rixen » 18 Nov 2013, 21:01
yep, and the mold for diecasting typically won't leave you much change from $100k !
Rixen
Postby sinner » 18 Nov 2013, 22:03
Rixen wrote:yep, and the mold for diecasting typically won't leave you much change from $100k !
Dude, start making Tonebender enclosure's, you'll become instantly rich :)
Any other future enclosure plans? A wah wah maybe?
Postby Rixen » 23 Nov 2013, 20:13
although I'd love to have a few more options, the set-up cost is a bit prohibitive. For now I want to increase the colour range available (any suggestions, people ?) and work on getting the price down...
Rixen
Postby sinner » 03 Dec 2013, 13:45
Rixen wrote:although I'd love to have a few more options, the set-up cost is a bit prohibitive. For now I want to increase the colour range available (any suggestions, people ?) and work on getting the price down...
Grey - these always catch my eye
And pink - that's for Phibes (he's gey)
...get one in green, I will give it to my bud Mictester when I see him
Postby Ice-9 » 04 Dec 2013, 19:47
Have you not thought of getting a powder coating kit, very cheap and you could do many different colours which should help you keep production costs down.
Ice-9
Has thanked: 144 times
Have thanks: 370 times
Next
Return to Stuff Seen for Sale
