HOHNER - Tri-Dirty Booster  [schematic]
Ben N
my favorite amplifier: Ampeg J12D Jet
Has thanked: 198 times
Been thanked: 54 times
Post by Ben N »
Dragonfly's:
Been thanked: 909 times
It's the one from DIYSB gallery? It's different to edkoppel's (different collector biasing and gain stages input resistors), but similar to the first one in this tread
Ben N
Post by Ben N »
Yup. I figured if it's a Big Muff, maybe the degree of variation between units is also BMP-like. :D
juanro
Has thanked: 51 times
Been thanked: 117 times
Post by juanro »
Sinner, if you leave that cap out you're getting a DC path from collector to ground, upseting the bias (and gain) of the stage. Either before the tonestack, or where you drawed it originally would be fine, as long the cap value is big enough.
Regards,
Juanro
La única verdad es la realidad.
jrod
Has thanked: 425 times
Been thanked: 46 times
Post by jrod »
sinner wrote:Look here, it cant be before tonestack
Ok, I see it now! Thanks!
juanro wrote:Sinner, if you leave that cap out you're getting a DC path from collector to ground, upseting the bias (and gain) of the stage. Either before the tonestack, or where you drawed it originally would be fine, as long the cap value is big enough.
Regards,
Juanro
So it makes sense? :) The cap value is 22nF
juanro
Post by juanro »
[quote="sinner]So it makes sense? :) The cap value is 22nF[/quote]
Yes.
edkoppel
Been thanked: 44 times
Post by edkoppel »
ok, it was nice and sunny out today, so I got to take some more pics.
hope they help!
(if they are too big, right click and view the image)
Tone Machines: vintage effects blog:
http://tonemachines.blogspot.com/
Great picts :thumbsup
Schemo almost done, just two missing values
Could you help me to fill it out?
Looking on layout posted earlier:
- C6 cap - I think it should be 100nF (.1Z code)
- C9 cap - I think it's around of 3n9 (392 code, or something like that)
Thanks a lot for all
edkoppel
Post by edkoppel »
C6 = .1Z 10v
C9 is kind of hard to read.
it the first two numbers are half there so it looks like it says either:
"3047 K 100" or
"0047 K 100" or
"2047 K 100"
I could try and take a pic, but i think you would see the same thing.
edkoppel wrote: it the first two numbers are half there so it looks like it says either:
"3047 K 100" or
"0047 K 100" or
"2047 K 100"
:thumbsup it's 4n7 :) You're awesome
So it's done. I'll have a look on the other unit picts posted here, and soon I'll post the final schemo, and vero layout
Thanks again
Any other unusual BMP vintage variants/clones you know about?
edkoppel
Post by edkoppel »
cool!
glad you figured it out.
well, big muff variations are what i mostly collect.
Besides the Dyna Soar Fuzz, that I am playing right now and sounds really amazing!
I have a few more weird japanese ones.
One of them that I have wanted to know just what the hell it is, is the Vestax Fuzz from (i think) the 80s.
It sounds like a really high gain Civil War muff but with an upper octave.
its pretty weird.
that might be a good one to post.
edkoppel
Post by edkoppel »
this:
edkoppel wrote:this:
Bring it on, I'll be more than happy to crank it :)
Kitrae
Been thanked: 29 times
Post by Kitrae »
Somehow I missed this thread. I could have saved you the trouble. Had a page about the TDB here.
http://www.kitrae.net/music/History_of_ ... #HohnerTDB
And the schemo.
Kitrae - Muff junkie
Big Muff Page
http://bigmuffpage.com/
Tonbender Timeline
http://www.bigmuffpage.com/The_Tonebender_Timeline.html
Cub
Has thanked: 102 times
Been thanked: 118 times
Post by Cub »
Now then, lads! :lol: I'm close to making a decision on my next build. It's decided on my next build and it's going to be a clone of this fine Hohner Tri-Dirty Booster. Thank you all in this thread for the work you've done. :applause:
I was wondering if you could help me out a bit with the the transistors, the 2N5172 that are in the original aren't exactly that high in the Hfe department. (100-500)
Would modern 2N5172 be all right and if so, what gain range is best suited for the Tri ? Or are there better suited trannies for this particular pedal ?
thank you 8)
agoldoor
Has thanked: 39 times
Been thanked: 21 times
Post by agoldoor »
Cub wrote:Now then, lads! :lol: I'm close to making a decision on my next build. It's decided on my next build and it's going to be a clone of this fine Hohner Tri-Dirty Booster. Thank you all in this thread for the work you've done. :applause:
thank you 8)
That's an interesting question you bring up. There's an electronics surplus store near me that has a few giant boxes of 2n5172's (the old ones), and so I've bought a few hundred from them over time. I would say that you're right, most 5172's are not on the high end of their spec. I went through all that I have and sorted them by gain, and I'd say somewhere around 10% or less are at the high end (400-500). But I have built the Tri Dirty Booster with these, and honestly, it roared even without my HIGHEST gain transistors. I'd say you could probably get away with 350 or so... but it's a taste thing, you should try out some different, commonly used Big Muff transistors (5088's and the like) and see what sounds best to you.
In a lot of ways the 5172's are like the 5133's that were in some of those early muffs... very hard to find transistors that measure on the "high end" of the gain spectrum.
