Himmelstrutz - Fetto [traced]
So if I wanted to try other FETS, what resistor(s) would I want to remove, and where would I connect a trimpot for biasing, on this "stripped down" layout?
R4, 7, & 10?
R4, 7, & 10?
- jallenshaw
I would replace r3/6/9 (12k's) with 20k to 50k trimmers....mind the pinouts of other FET's
FWIW, I have built 2x Fettos, and the 2SK170BL is best to my ears, and the 12k is perfect....no trimmers needed.
They can be had on eBay for reasonable cost if you shop carefully.
JAS
JAS
Just looking at the vero [ non-stripped] , would any of the dip switch selections benefit from being outside ? Maybe the voice or gain ?
Nice! I might not bother then. From what I can tell, it's kinda like the DLS meets the Riot, but better.jallenshaw wrote:FWIW, I have built 2x Fettos, and the 2SK170BL is best to my ears, and the 12k is perfect....no trimmers needed.
Another question for anyone who's able to answer: on the Fetto Custom, there's a bass and treble control. Any pointers for incorporating that into this stripped down layout?
So I want to make a PCB for the minimal layout (that is, all default settings).
I'm basing it off of this vero layout:
Would someone mind looking at my adapted schematic to help verify it's correct?
- pamaz
Sorry, I've not checked the schemo yet, but the first thing i see is that you are basing it out of j201 fet. Mind that 2sk170 have a different pinout than the j201. And 201 in this circuit are not a good choice.
Just finished this yesterday , awesome pedal . I used matching 2skr170bl and all 3 biased at 4.4v with the 12k resistor and 4.6v with 13k which is where I left it
Of course! Oversight on my part. Put in the correct trannies.pamaz wrote:Sorry, I've not checked the schemo yet, but the first thing i see is that you are basing it out of j201 fet. Mind that 2sk170 have a different pinout than the j201. And 201 in this circuit are not a good choice.
Assuming my adapted schem is correct, here's the work-in-progress of the PCB!
It's my first ever attempt at laying out a PCB, so go easy!
Larger pads, no problem!
I can make a version with larger traces too! I was planning on getting a few of these made up but a version that's easy to etch at home is a great idea.
Updated the PCB. It's not as pretty, but it should be easier to DIY.
Also, here's a version ready to etch. NOTE: this is assuming my schematic is accurate. Still need a few people to take a look at help make sure it's verified (again, it's based off of the simplified vero, which simply eliminates the trimmers and headers, leaving only the components necessary to achieve default settings).
http://roestudios.com/dump/fetto-minimal-board-bare.jpg
Realized that when I increased the traces, I ended up with some orphaned ground plate.
The JPG of the PCB and the DIY-ready version have been fixed.
Really hoping to get someone to help me verify so I can build this bad boy.
- batteryacidtea
What is this solder pad floating alone on the left, bottom side of the pnp?
A victim of Photoshop! That's the input. DIY version fixed.batteryacidtea wrote:What is this solder pad floating alone on the left, bottom side of the pnp?
- Frabbio
Hi, nice pcb. You should enlarge the pads using the restring parameters in eagle, you can find them in the lower part on the left sidebar. A good value is 16-18 for the bottom for diy etching.
Im a beginner-grade-solder and electronics guy.
The stripped fetto is my second pedal build (after tremulus lune - which works nice) and i have a BIIIIG Problem.
I soldered everything together and plugged guitar and amp in and i only have some very loud and "popping" sound when i strum very hard and all pots turned to maximum.
What makes me crazy is:
I checked everything twice, even desoldered, tested every part and soldered a new stripboard --> same Problem.
I bought a 10 pack of "cheap" chinese 2SK170BL labled k170bl. I checked them with the AVR transistor testerhttp://www.mikrocontroller.net/articles ... English.29 and they seem to be okay. It says: N-JFET; I=1.1mA; Vgs=0.80V (independently how i test them (SGD or DGS))
After the first problems i used little sockets instead of soldering the jfets to the board. When they are assembled i have only 0.7v on all three Drain and 0.7v on all three Source. (When i take the jfets out i have about 8.5v on the Drain Sockets --> so no Problem on the voltage rails)
The schematic http://revolutiondeux.blogspot.de/2012/ ... rtion.htmltells me there should be about 6.5v on the Drains. But why do i only have 0.7v?
I feel like getting crazy and really need some experts help. I fear its just a little mistake and every will work nice %)
