Noah's Ark - Distortion M
- invictus
to get along with the program, i'll post each model in separate threads.
for good image resolution, i'll attach the original *.tif file which can easily be opened with mspaint.
according to the designer, the "M" in the name means "Marshall" so it's supposed to be a Marshall in a box... see for yourselves!
- Noah'sArk Distortion "M" schematic
- Noah'sArk Distortion M .tif (18.43 KiB) Viewed 4938 times
"im the master of my fate, im the captain of my soul... " -invictus
- soulsonic
How is this supposed to be a Marshall in a box?
Well, we shall have to build one and see. Maybe it is a good example of how you don't actually have to mimic a circuit (like those JFET amp simulators) to actually mimic the sound.
- analogguru
"Funny" circuit:
second opamp has a gain of 13.
1S 1588 diodes will clip at 1,3V ss. This means when they start to clip the second op long time ago will have run into the power-supply-rail.... perfect sound....
- analogguru
Hab das gleiche Problem - die Lösung dafür:kusi wrote:hi,
hmm, i just see a X when i want to download the schematic... could someone please uplaod it as *.jpg or similar?
thanks, kusi
rechte maustaste drücken, save to harddisk und dann mit einem bildbetrachter anschauen.
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
I can only see an X too - how didyou download it Soulsonic??
Any chance of uploading it here??
- analogguru
I have the same problem (with all files) - the solution:
right click your mouse save file to disk and view it with your picture/grapchic program.
- kusi
i think the Vref-connection of D4/5 is an error in the schematic.... i hope itanalogguru wrote:"Funny" circuit:
regards, kusi
- analogguru
why ? they are dc-decoupled with C9-C11 and from an AC-viewpoint C15 acts like nearly a short to ground....kusi wrote:
regards, kusi
- gnognofasciani
You can find samples on the noah's ark website
Search button is your friend
- ieatyouforbreakfast
cant find sound samples anywhere on the site.. can someone kinda direct me to them?
- soulsonic
Wow, that thing totally has that 80's modded Marshall sound! It sounds like I'm listening to a Ratt album!
Never believe what you here in soundsamples !!!!
A while ago I've downloaded a sample on a manufacture's webite for an OD with a tuned Marshall sound (sounded quite convincing) and then I discovered the same sample on another manufacture's site (but there as a sound demo for an Egnater tubeamp).
JHS
JHS
- lynessmy
Is the doubt cleared on the schematic shared by oscarv77?
I had create a layout base on that schematic.
If anyone wanted to confirm that schematic / my layout...here you are....
Diode is 1S1588 as mentioned in the thread above.
I believe the IC is JRC4580D.
1 Meg resistor between 223 & 102 cap are not in the schematic. It was added in case there is a need for a pull down resistor to eliminate switch pop.
