Carlsbro - Echo  [schematic]
Has thanked: 232 times
Been thanked: 888 times
This one:
http://www.effectsdatabase.com/model/carlsbro/alu/echo
which is this one:
http://www.dirk-hendrik.com/temp/Carsbro_Echo.pdf
Nope. A R5101 Reticon is not suitable for a new project. They're more rare than Pygmee foreskin leather. But since I have one of these with a (thoroughly) confirmed dead Reticon a rework for a PT2399 is in the make. Not analog anymore but still with the same heavy filtering which will then be called "analog voiced" :blackeye
briggs
Has thanked: 27 times
Been thanked: 128 times
Post by briggs »
:thumbsup I look forward to seeing this one Dirk! Work you're magic... "Pygmee foreskin leather".... :applause:
I am Klon.
ttdom
Post by ttdom »
i still have the original schematics somewhere, mailed carlsbro a few years ago and they sent it, any interest for that? could make a highres photo
Definitely. When I traced this one about 2 years ago I had quite a pleasurable email conversation with Carlsbro as well. They did not have this stuff archived anymore so were happy with all support that enabled them to help their customers with enquiries about old junk.
Compare that to "they're ripping me off by tracing my product" howlers :thumbsup
ttdom
Post by ttdom »
ill have a try tomorrow, when there's more light in my room;)
apparently there's a mark 1 and 2 version of which i have both schematics..
got the pedal too, nice, tho bit lowfi
ttdom
Post by ttdom »
MK1
schematics mk1
schematics mk1
ttdom
Post by ttdom »
MK2, the copy was a bit messy but i think all is readable
ttdom
Post by ttdom »
and they even sent me a nice infosheet,
supporting products from 25+ years ago, not bad indeed
ttdom
Post by ttdom »
that mantis sounds quite a bit cleaner, nice.. judging from the youtube that is
Cool to see the original!! Bedankt! :applause: :applause:
How about some color ;) ?
sonathanjim
Post by sonathanjim »
Well this thread has turned out very useful.
Would anyone have any idea why this pedal might have a faint "ghost" wet signal coming through even when the effect is off?
Looking at the schematics I have the MK2 version.
From the notes on the schematics it looks like mine hasn't had the first change made but the second resistor hasn't been changed.
Oneoff7
Post by Oneoff7 »
Thanks so much for uploading the schematics! You helped me save
My echo and also modify it to work with external power adapter,
Add a power swich and reverse protection diode.
Now looking into a true bypass wiring with a new swich,
And maybe add a 15V power regulator (although the circuit has a 15V zener
Diode already).
The only concern I have is the ‘metalic’ Sound the repeats
Have with a very long delay and ‘swell’ knob on high.
I guess it’s the nature of this unique reticon chip?
driab
Post by driab »
Thank You for all of the information. I recently acquired a mk1. Does anyone know how much current these draw? I’m in the US and I either need to convert to DC or find a voltage adapter. Either way, it would be useful to know what sort of wattage I’m working with.
Thanks in advance
