TC Electronic - Spark Booster  [traced]
miklax
Been thanked: 19 times
Post by miklax »
Hi there friends,
I've received a faulty Spark booster for repairs, and after trying everything I could imagine, and with no success, along with my client, we've decided I should take apart, trace it and build a new one.
I've traced it, and already build it, but the resulting boost is not very noticeable. Not near the original.
I'll attach the schematic and Hi-Res pics from the board, can anyone take a look? Maybe I've skipped any connection.
https://www.dropbox.com/sh/avx50cks3pryvjd/pTJFjXekaA
Cheers
spark booster.pdf
(232.79 KiB) Downloaded 1195 times
miklax
Post by miklax »
Hi there!
I've found a little bug on my schematic!! :)
I'll update the corrected one! It was on the R67 connection.
I think its 100% now... will see tomorow.
By the way, there are many components i've ignored, as they are not present in this pedal, or are used for TC's bypass scheme..
Cheers!
Spark Boost.pdf
(232.87 KiB) Downloaded 841 times
commathe
Been thanked: 7 times
Post by commathe »
Awesome! I had been looking for this.
andershenrik
Post by andershenrik »
Hi miklax
Thanks for your good work, but i think something is wrong with the drawn conections to IC2b . The amplification is feedbackresistor/r5 . and the feedbackresistor is 0R !
so nothing will pass.
kind regards anders
andershenrik
Hi again.
It might be right after all . Ic 2b is making midpoint voltage.
sorry for the noise.
kind regards anders
miklax
Post by miklax »
Wellll... I've re-verified the schematic, and my first version is correct, at least regarding the connection I thought it was wrong..
I'm missing something for shure!!!
lukatosh
Has thanked: 33 times
Been thanked: 186 times
Post by lukatosh »
Hello miklax!
Is there a way that you could post some Guts to help in the trace?
miklax
Post by miklax »
lukatosh wrote:Hello miklax!
I've uploaded some pic's I've taken prior and after the initial IC-Swap. (I wanted to fit some OPA2134's in there). Don't know if they will be any good for this..
Dropbox Folder
Also, I've realized that two of the cap's had incorrect value.
Updated schematic in here ;)
I'm really getting a hard time with this one... Any new ideas?
Cheers!
Spark.pdf
(234.68 KiB) Downloaded 550 times
alexradium
Has thanked: 64 times
Been thanked: 68 times
Post by alexradium »
do you want ideas to make it work or to guess if the schematic makes sense?
IMO there is something missing,but i cannot confirm it without having it under my eyes.
Anyway it looks a lot like a RC Booster,with a filter in front.
Not too bad priced though...
How is the opto chip used?
is it like in the Voodoolab series ?
coldcraft
Has thanked: 38 times
Been thanked: 85 times
Post by coldcraft »
please allow me to analyze. The input is a bootstrapped Opamp buffer. Then it goes to IC3A&B, which is a lot like a Bluesbreaker or King of Tone. From there it goes to a non-inverting amplifier (IC6A) and onto IC6B which is an active Baxandall, not unlike the Xotic Pedals.
IC2B is just supplying a Buffered 4.5V signal.
coldcraft
Post by coldcraft »
Here's my redrawn schem of just the audio portion. The 4.5V buffer has been dropped and is basically what I have called VR. The clipping diodes come between VA and VB
miklax
Post by miklax »
Hey Coldcraft!
Thanks for your schem!! ;) Great work!
A few questions.. For the VR, we can simply use a regular voltage divider?
On my schematic, I've got 220 nF for C41... you used 1uF (C12).. any particular reason for that exchange?
Also, you use 1K on R17, when the original one was 47K, any reason in particular also?
Cheers!
coldcraft
Post by coldcraft »
i just forgot to change the value of those after i copied them.
coldcraft
Post by coldcraft »
miklax wrote:Hey Coldcraft!
Cheers!
you could just use a divider, but you'd have an extra opamp anyway, if using duals and/or a quad so I think its best to use the 4.5V buffer.
miklax
Post by miklax »
So, I've rearranged my schematic, according to your version, and here it goes!!
Full schematic (minus truebypass switching, that uses an optocoupler similar to the voodoo lab circuitry).
I'll test it tomorrow, to see if it's finally 100% working!
I've changed the two cap's for the correct value and everything seems to work ok.
I'll keep you posted!! ;)
Cheers!
Spark Booster.pdf
Spark Booster final version
(236.98 KiB) Downloaded 1184 times
alexradium
thanks for the schematic
It should be interesting to point out the choice of capacitors,there are through hole and smd,i heard smd elcos have a bad reputation soundwise as coupling caps.
Anyone can confirm this?
coldcraft
Post by coldcraft »
r6 and r47 puzzle me. I've not seen resistors to actual ground like that with opamps used at a 4.5V virtual ground.
marshmellow
Has thanked: 20 times
Been thanked: 127 times
Post by marshmellow »
coldcraft wrote:r6 and r47 puzzle me. I've not seen resistors to actual ground like that with opamps used at a 4.5V virtual ground.
They are supposed to bias the opamp into class A operation. Of course a resistor makes for a rather primitive current source, the current draw will be dependent on the audio level at the output.
miklax
Post by miklax »
A little update:
The schematic is now verified! Works great!!
Cheers!
miklax
Post by miklax »
By the way..
What do you think about the active filter section?
Any Idea on how to calculate the corner frequency for each of the switch positions?
https://www.dropbox.com/s/l1p41wjfl27o8zq/Untitled.jpg
Cheers!
