Dunlop - Band of Gypsys Fuzz Face Mini FFM6
- beedotman
New fuzz from Dunlop, ugly enclosure ('couse it's small) but can be interesting. Anybody have it? Some gut shots please?
http://www.turretboard.org 4 life!
- DrNomis
- Has thanked: 98 times
- Been thanked: 279 times
I'm guessing that it's same as, if not similar, to the turquoise BC108C Jimi Hendrix Fuzz Face that Dunlop manufacture, but it sounds to me that they might have tweaked the circuit a bit, would be interesting to see what's inside one of these though......
- LaceSensor
nice switch pop at the end
- FuzzMonkey
So similar to a Roger Mayer Axis Fuzz then?Skreddy wrote:Is supposed to be an Octavia circuit but without the octave-up. I always hated that skronky sound from "Purple Haze," but it is unique at least.
- FuzzMonkey
Nice!es-347 wrote:Nudity!
- nooneknows
Any good hearted guy boldly tracing it around?
thank you
thank you
Great Pedal! I love it. Cleans up real nice when you roll down the volume.
Quite different from other Fuzz Face pedals being based off the Octavio circuit minus the octave.
BC108's for transistors. Sounds best with a stack.
- tube-exorcist
What are you vomitting about ? Too much dope today ?Axeman.Bodie wrote:Great Pedal! I love it. Cleans up real nice when you roll down the volume.
There is not a single Fuzz Face out there based on the Octavio circuit, otherwise it wouldn't be a Fuzz Face. And a Fuzz Face circuit is totally different from an Octavio circuit.
I'll excuse your shitty attitude, but you couldn't be more wrong. Look up anything about this pedal and they'll tell you this Fuzz Face was based off the Octavio circuit because they were unable to match Jimi's BOG tone with conventional Fuzz Face circuits. If you're going to be an asshole, at least be correct.tube-exorcist wrote:What are you vomitting about ? Too much dope today ?Axeman.Bodie wrote:Great Pedal! I love it. Cleans up real nice when you roll down the volume.
- tube-exorcist
Now let's see:
If you have a tube and someone writes "transistor" on it, does that mean that it is a transistor or still a tube ?
If someone writes "clever" on your forehead, does that prove that you are really clever ?
And if a company takes a red box, writes "Fuzz Face" on it, does that proof that there is really a Fuzz Face circuit inside ?
For clarification:
This is neither "The Gear Page" nor a Dunlop-promo-forum where nonsense is spreaded. This is a technical forum and we are talking here about - you got it - CIRCUITS. And the Fuzz-Face-CIRCUIT - not something in a red box with Fuzz Face written on it - is a uniqe circuit with 2 transistors:
http://www.geofex.com/article_folders/f ... fftech.htm
It was introduced and produced by Arbiter, Dallas Arbiter or Dallas Music Instruments:
https://en.wikipedia.org/wiki/Fuzz_Face
Got it ? Really ? I am so proud of you.....
For clarification:
- induction
With all due respect, all he said was that this pedal is different from the other pedals with 'Fuzz Face' written on them since it's based on a different circuit, and that he likes it. It seems that you agree with him, at least about the first part. I don't understand what you're so upset about. He wasn't the one who decided to write 'Fuzz Face' on the box. I get the impression that you misread his post.
- Nocentelli
- Has thanked: 1155 times
- Been thanked: 954 times
Yes, a "voltage inverter" using a 1044 or 7660 will allow this
- mictester
You don't need to. The "inverted" Fuzz-Face is a well-known circuit. However - this one uses NPN transistors so doesn't require anything smart.cerelac wrote:ANy ideas on how did dunlop achieve positive ground FF AND ability to daisychain too? ..using something like the MAX1044?
Incidentally, the one of these I saw is just a silicon fuzz face - using up some stock of old metal canned silicon transistors (because you can't get the tones out of plastic). It has a couple of base to collector capacitors to roll the worst of the top end off, and has a lowered feedback resistor with a bypass capacitor. It's really nothing special, and should retail at about $24.99 - they'd still be making several thousand percent on their manufacturing costs!
I simply can't believe the stupidity of guitar effects purchasers. Churn out a piece of sub-standard crap, stick a "brand-name" on it, claim that it has some connection with a great old recording ("sounds just like....") and profit spectacularly! You can make even more mark-up if you get some "star" guitarist to endorse it.
