EHX - (Super) Space Drum (Percussion Effect)  [schematic]
Ruprecht
Been thanked: 5 times
Post by Ruprecht »
My Super Space Drum clone with in-built delay
JuliaDee
my favorite amplifier: 2N5088
Completed builds: Invented and designed: EH-8000 Guitar Synth, E-H Space Drum, Super Space Drum, Crash Pad, Sequencer Drum, Clockworks. Designed: Zildjian Gen-16 Acoustic-Electric Cymbal System.
Been thanked: 107 times
Post by JuliaDee »
Nicely done! Warms my heart :)
Ruprecht
Post by Ruprecht »
I´m fan of analog drum synths :)
My Synare 3 and Coron DS-8 clones
And Synare 3 "UFO" clone :) Built by me from scratch :)
JuliaDee
Post by JuliaDee »
Those panels are just amazing. How are they fabricated? Do you do it yourself or have them made?
julia
SpencerPedals
Post by SpencerPedals »
That's killer. I've had no time to build lately, but when I get a chance this is on my to-do list. Looks and sounds amazing—congrats!
Ruprecht
Post by Ruprecht »
I made myself small CNC milling cutter some years ago so all this is my work :)
Sheet of tin is engraved first and then bended. Wood side panels are simply milled.
JuliaDee
Post by JuliaDee »
Ruprecht wrote:I made myself small CNC milling cutter some years ago so all this is my work :)
Beautiful. Nicest DIY work I've ever seen. Kudos to you!
julia
P.S. There's a Clockworks just came up on ebay - $1,100 :shock:
Ruprecht
Post by Ruprecht »
apollomusicservice
Has thanked: 65 times
Been thanked: 828 times
Post by apollomusicservice »
Very nice.
satanicmajesties
Post by satanicmajesties »
Hello,
I'm interested in making one for fun!
Where can I find Xtal mic or can I put another thing in order to replace the xtal?
uncleboko
Has thanked: 58 times
Been thanked: 41 times
Post by uncleboko »
satanicmajesties wrote:Hello,
https://www.ebay.co.uk/p/20-Pcs-Electre ... 7675.l2644
These should do the trick, you may need to play with the peak follower gain.
satanicmajesties
Thanks for your reply.
What is peak follower gain?
Is there a component to add, change or change value?
JuliaDee
Post by JuliaDee »
Crystal mic basically = piezo disk. Back in 1978 we did not have piezo disks :) I would not recommend an electret mic - they are fragile and they need a power supply. Depending on how the piezo is mounted and how hard you hit it, you might want some kind of high-voltage protection to protect the rest of the circuit (Yamaha actually puts spark gaps on their PCBs for this!). But if you just stick it to a hard flat surface as in the original Space Drums, it probably won't be necessary. Voltage generated is proportional to how much the disk flexes.
uncleboko
Post by uncleboko »
Ah yes of course I forgot about the power requirement!
satanicmajesties
The missing value of resistor R16 is 330, according to original schematic.
Thanks to Julia
uncleboko
Post by uncleboko »
uncleboko wrote:Ah yes of course I forgot about the power requirement!
I'm used to plugging a pair of electret capsules into my digital recorder, which has plug in power, when recording a gig.
