BJFE - Emerald Green Distortion Machine  [traced]
Re: BJFE - Emerald Green Distortion Machine
Postby Manfred » 01 Sep 2018, 08:41
jalmonsalmon wrote:So ...
:scratch:
MP38A's work for this and sound more or less the same as the CV7351's?
Like blind fold comparison test? :secret:
I am not sure, since the frequency response is not the same on the low end.
Theres is a diffrence from about 10db @ 10 Hz, that means there is three times less low frequency level using the MP38A below 30Hz,
but I think it is finally not audible.
Next, will omitted more specifically change the capacitor between base and collector, to see the influence on the frequency response.
The next task is the measurement of each FET-stage seperatly.
To the end with, I will build the device, but that is a winter work.
Has thanked: 1080 times
Have thanks: 675 times
Postby Manfred » 02 Sep 2018, 17:15
As announced, here the frequency responses for differten Caps placed between base and collector.
dv8r601 (04 Sep 2018, 03:23)
Postby Manfred » 05 Sep 2018, 03:07
Output curves and frequency responses for different "Voice" potentiometer settings.
On the measurement frequency of 1 kHz, the potentiometer setting has had no influence on the shape of the clipped signal curves.
On the annotation in last columns the "k" is missing, 50 means 50k.
Postby Manfred » 06 Sep 2018, 16:34
I mad further frequency response measurements because nothing has changed significantly for potentiometer resistances greater than 5 Kiloohms.
That corresponds to the half rotation of the "Voice" button, due to the logarithmic potentiometer.
Those values are 1 Kiloohm, 2.2 Kiloohms, 3.3 Kiloohms and 3.9 Kiloohms.
In summary, on Stage 1 the "Voice" button affects the low and low mid frequencies on its lower half rotation,
the mid and high cut frequencies remained largely unaffected.
Postby Manfred » 09 Sep 2018, 06:29
Output curves and frequency responses for different "Voice" potentiometer settings of stage 3.
The value of R_pot means the resistance between terminal 2 and terminal 3 of the "Voice" potentiometer, so the right stop corrospondes with 0 Ohms.
Using the 4.7 nF capacitor, the potentiometer setting has not a noticeable influence on the frequency response,
so I using a 47nF capacitor, that gave a marked change, but only up to a resistance of 5.1 Kiloohms.
This gives only a small rotation left away from the left stop.
Maybe this capacitor have been read incorrectly.
Later on, the build circuit make the truth come
Postby Manfred » 10 Sep 2018, 22:46
The final chapter discusses the clipping circuit.
For comparison purposes I also measured the circuit using 1N4148 diodes.
The spectrum shows amplitude peaks on the odd harmonic multiples of the input frequency.
The amplitude amounts of the harmonics are significantly greater using the BY458 diodes.
Users browsing this forum: No registered users and 9 guests
