bajaman wrote:Hi schemripper
You could try decreasing the 2 x 47k plate load resistors - try 22k for example when using the lower plate impedance 12 AU7 type tubes - A 12AT7 might work okay in here too.
Cheers
Hey, Bajaman, I've said it before but what a great circuit. The 12AT7 did work, but was still a bit too much.
I found a very old 12u7 (12v ex car radio valve- just like Brian May! ) in a dusty box in the very back of the workshop. I swapped in some 78/7912s to get the voltage down, and ended up with 18k for the plate load resistors- that's probably the dubious state of the valve more than anything. I think it's probably that the 12u7 is operating at its intended voltage, but it has that little bit extra sweetness over a 12au7 to my ears.
It also opens up the possibilities of running it at a regulated 12v dc, but that's too much hard work when I already have a working device Any other little fiddles I tried didn't provide sufficient returns for the effort. The tone stack (what there is of it... Simple and effective) was pretty much spot on.
Overall- it suits my needs, but if anyone else tries this, YMMV. Remember- a 12(a)u7 is not a gain monster. It's about 20 vs 100 for a 12ax7.
Hi Baja and Schemripper,
I also want to play with tubes. What do you think will make a bigger difference: different 12AX7 manufacturer or different tube type (ECC83, ECC82, ECC81). My logic is to first find the best tube type for sound that I am looking for (buying cheap chinese tubes ) and than to tweak it further if necessary with more expensive one of the same type. Also is playing with plate resistors affecting too much sound or this is only to get optimal voltage for longer tube life.
Just to report back that pedal worked and that I have settled with 12AU7. 12AX7 sounded more like a BRIT amp overdrive and it did not work well for with my strat -> 69CS -> 5E3 setup. It is off course very subjective. Thanks Steve !!!
I was wondering if the opamp gain si based on other pedal? I know gain pot on feedback is used by tubescreamers but the whole gain until tube is based on other? I'm thinking in bulilding only that part tu use with only tube pedals like matchless and valvecasters.
Haha I have one of these... Bought it second hand in Akl.
Great sounding thing.
A bit hard to use nowadays though, as I have a pedal board powered by a onespot cs12, which doesn't do 16v AC.
Cool to read up the backstory on here though, I had no idea about its history. I was directed here from Reddit.
Thanks bajaman
I'm wondering if a 18v ac supply would be better...With 16v ac after the 4007 it drops to 15.5v and I thought regulators worked better with a 1v or 2v margin. But I might be wrong, I'm not an expert at all. I'm sure there's an explanation to that.
Ok. We're dealing with AC...I wasn't aware of rms & peak definitions. We have 16Av (rms) and that's around +22.5v (peak) and -22.5v(peak). So each regulator see 22.5v. Everything ok.
Im having a weird problem, i get no distortion, only clean sound when gain is off and when fully on i get no sound at all, volume and tone controls work
My ic voltages are
1,2,3,5,6 are 0v
Pin 4 is -15v
Pin 8 is 12v
Pin 7 is 11.41v
pictures please those voltages look strange - pin 7 on the IC should be 0, pin 8 should be +15v and the tube voltages are way out - where is the +12v ?? something is decidedly screwy with your power supply
i used 7812 instead of 7815 till it gets here... managed to find the voltages on the thread and chased down pin 7 on the ic, cause that was the the main culprit, found a missing link (using wires for the pots and one of them struck out and wasnt touching the board right. now all is fine, sounds KILLER
