Keeler Designs Push
mirosol
my favorite amplifier
Been on Bogner for quite some time now.
Completed builds: Over 900 and counting.
Has thanked: 162 times
Been thanked: 372 times
Post by mirosol »
So. There was one of these for sale as a defect unit on a local forum. Description said that there is "some bad contacts or something", but the price was realistic. I already knew this one will be gooped, but went ahead anyway. Got it in the mail and ripped it open as soon as i found the time to do so. Sure enough. Massive loads of clear and black goop. The only real issue with the unit was the standard 3PDT stomp, which didn't work properly. Now, i had it open on my desk and... Well. The pedal sounds pretty decent, big and somewhat cool with its high-ish gain. I didn't hear it like it would be a straight up clone of anything i know, so i was somewhat interested. Took my exacto knife, 12V spare iron, bigger knife and a few other tools out. About an hour or two later, i had pile of crap on my desk, but the circuit was finally bare. All it took was some moderate violence and lots of patience. I did break the power supply current limiting resistor, 47p cap at the feedback loop and also did some damage to the power filter cap. Replaced those and ordered suitable pots to replace the original ones (which are quite horrible). Now that the goop is gone, those standard angled pots will fit in there nicely. Did the trace, figured it should work, drew a stripboard layout and built it. Sounds exactly like the original. Well then a gain.. It's very low parts count design. Wasn't exactly what i was expecting. Simple, yet quite cool design. Fat TS clipper stage, followed by a Rat-like "tone" control, which is buffered - this followed by a standard volume control. IMO, this could have gained a lot more respect if it wasn't for the goop. Or the choice of pots. Funniest part is definitely the message left for me..
Anyway, here are the results.
Parts list / BOM:
All resistors standard 1% metal film, 1/4W
R1 1M2
R2 100K
R3 1K
R4 10K
R5 10K
R6 10K
R7 10K
R8 10K
R9 10K
R10 100R
C1 100n/63V poly
C2 330n/63V poly
C3 47p/50V ceramic
C4 6n8/63V poly
C5 1u/63V poly
C6 47u/25V alum. electrolytic
C7 47u/50V alum. electrolytic
Gain B500K
Tone B50K
Volume B100K
OP1 sanded, possibly 4558/072, or some other dual opamp
D1 unmarked Si, possibly 1N4148, could be a zener
D2 3mm Diffused red LED
D3 3mm Diffused red LED
LED 5mm Clear blue
And the photos. And the schematic. And the layout.
Consider all verified.
Photo from the middle of the process...
Degooped component side. Note the "Curious?" message.
Solder side.
Solder side.
Pile of crap from the process.
Traced schematic drawing. Verified.
Stripboard layout (with polarity protection modded my way). Verified.
http://mirosol.kapsi.fi/
FeVeR2112
Has thanked: 22 times
Been thanked: 28 times
Post by FeVeR2112 »
I find the silkscreen text of "Curious?" pretty funny... Only visible after de-goop... :lol:
dv8r601
my favorite amplifier: Peavey ranger 212
Has thanked: 382 times
Been thanked: 20 times
Post by dv8r601 »
I built this up at work tonight. Easy and very good sounding overdrive with a good bit of gain. I appreciate all your work mirosol, you are a champion among men.
Has thanked: 1097 times
Been thanked: 699 times
Post by Manfred »
dv8r601 wrote:I built this up at work tonight. Easy and very good sounding overdrive with a good bit of gain. I appreciate all your work mirosol, you are a champion among men.
Which type of OpAmp did you install?
mirosol
Post by mirosol »
I put 4558D in mine. No audible difference between the stripboard and the original unit.
+m
dv8r601
Post by dv8r601 »
Damn. My bad. I just saw you asked what opamp. I used a rc4558 and a jrc4580. It works great with whatever you put in it.
Post by Manfred »
I made board layout copy according the schematic and the shots and added the hidden tracks by guess.
PushComponents.pdf
(11.59 KiB) Downloaded 27 times
PushComponentSide.pdf
(9.1 KiB) Downloaded 28 times
PushSolderSide.pdf
(9.55 KiB) Downloaded 26 times
PushComponentSideMirrored.pdf
(9.38 KiB) Downloaded 22 times
PushSolderSideMirrored.pdf
(9.84 KiB) Downloaded 21 times
Post by Manfred »
I made a single sided board version, the conducting paths on the components side were replaced by wire jumpers.
PushComponentsSingleSide.pdf
(11.6 KiB) Downloaded 28 times
PushSolderSingleSide.pdf
(11.23 KiB) Downloaded 26 times
PushSolderSingleSideMirrored.pdf
(11.45 KiB) Downloaded 25 times
tete1805
Post by tete1805 »
Hello everyone! (First post ever.)
I had to tear down the goop on mine after plugging a 12v by mistake.
As you should see on the picture, the opamp on mine wasn't sanded and it's a TSH22IN.
I struggled a bit and I broke two resistances and the diode on the way (although I'm pretty sure it was dead already), but I hope I can fix it.
On the schematic, I think there's a cap that is mislabelled, C7 is there twice instead of C7 and C6.
However, both are 47uf, so it doesn't matter.
Thanks for the hard work mirosol, it helped a lot to see what was beneath the goop to pull it out.
rhandy gaye
Post by rhandy gaye »
Hi, lots of hard work done here, but I can’t see a pad for the 9v connection on the PCB layout copy.
Also, on the vero layout, 9v enters the PCB and passes through a diode, then a 100 ohm resistor, but in the schematic the first diode goes to ground.
Cheers, Randy.
rhandy gaye
Hi, I worked it out.
On the layout copy, the 3rd pad in is not a ground pad, and is not joined to th ground pad to the right.
The 3rd pad in from left is 9v, and there is a topside trace that connects to diode (going to ground), and 100 ohm resistor.
Cheers, Rhandy
Post by Manfred »
Sorry, I forgot the 9V pad.
I added to the layout now.
KeelerPushDoublesided9VPadComponents.pdf
(13.62 KiB) Downloaded 9 times
KeelerPushDoublesided9VPadComponentSide.pdf
(2.9 KiB) Downloaded 9 times
KeelerPushDoublesided9VPadSolderSide.pdf
(3.6 KiB) Downloaded 10 times
KeelerPushDoublesided9VPadSolderSideMirrored.pdf
(3.57 KiB) Downloaded 8 times
KeelerPushSinglesided9VPadComponents.pdf
(13.72 KiB) Downloaded 13 times
KeelerPushSinglesided9VPadSolderSide.pdf
(4.25 KiB) Downloaded 14 times
KeelerPushSinglesided9VPadSolderSideMirrored.pdf
(4.23 KiB) Downloaded 12 times
SprintLayout6 file:
KeelerPush.zip
(29.25 KiB) Downloaded 16 times
HamishR
Been thanked: 36 times
Post by HamishR »
I built this - thanks Miro! It's a very cool sounding pedal but I seem to need to have the tone control almost full to be usable. Otherwise it's quite dark. Maybe I should try an audio taper pot there? Also thinking of reducing the B500K gain pot to B250K as it gets way gainier than I need.
Overall my Les Paul loves this pedal. It kinda reminds me of a cross between a Honey Bee and a Rockett Calibre 45. Cool overdrive indeed.
MoonWatcher
Has thanked: 41 times
Been thanked: 43 times
Post by MoonWatcher »
HamishR wrote:I seem to need to have the tone control almost full to be usable. Otherwise it's quite dark. Maybe I should try an audio taper pot there?
You may want to try to either wire a log taper pot "in reverse," like a Rat's filter control, or get a reverse-log taper pot, if wiring it "normally." You might also try reducing the value of R7. Something like 2k2 might be a better fit, tonally. Actually, reducing the value of R7 as a first step may work out better, and you may not have to change the pot to one with a different taper.
HamishR wrote:Also thinking of reducing the B500K gain pot to B250K as it gets way gainier than I need.
Alternatively, you could switch R3 to 2k2 and C2 to 150n, to get an equivalent effect to reducing the pot value.
HamishR
Post by HamishR »
Wow - thanks! I would never have known to try those things. I will now and let you know how it works out.
HamishR
Post by HamishR »
Well it turned out easier to replace pots today and I had a C50K and a B250K so swapped the Gain from B500K to B250K and the Tone to C50K (as you suggested) and it worked perfectly. I may still experiment with the board changes next time i build one, which I most likely will. I may also try installing a Timmy-style bass pot. I like having control over the low end - I don't know why it isn't included on more ODs.
So thanks for the suggestions and thanks to Miro for the trace. I really like this one with my Les Paul.
bool
Been thanked: 14 times
Post by bool »
You could also try to change values for C1/R2 combo - to 47nF/220k for example.
HamishR
Post by HamishR »
Thanks Bool! I may try that.
In the meantime as I was looking at this quite simple circuit it made me think I could add a Timmy-ish bass control to it. So I did. And I REALLY like the result! I think I like it better than the stock Push. While I don't think I have done a masterful job at all it's good enough for me to use. I'm sure somebody who actually knows what they are doing would have come up with something clever, but this circuit has achieved everything I wanted to achieve - make a pedal like a Push but with a little more low end on tap if I wanted. I am finding that if I put Bass at around noon it sounds much like a stock Push. I like it at around 2.00 - a little more low end oomph. One thing I wasn't expecting was a little more sparkle - maybe it's because I am effectively slightly reducing the mids? Increasing the Bass further past 2.00 increases the grind too.
As I say I don't really know, but i really like this overdrive. With a 335 I can almost play clean and get a nice dirty bite by digging in a little harder. Great dynamics. If anyone wants to try a Push with a little more adjustability around the low end, try this (With thanks to Miro for his original layout!):
tete1805
Post by tete1805 »
I finally got time to fix mine, it's working fine now!
However, indeed, tone is almost always at 3 o'clock.
MoonWatcher, I might try the mods you're talking about, but I'd like to understand what I'm doing for a change. :)
Lowering this resistance (R7) will raise the frequency of the low-pass filter, is that right? Would lowering the value of C4 achieve the same result?
Regarding gain, I'd like to lower it as well, like HamishR mentionned, it's a bit much.
This, I don't really understand, can you walk me through the gain structure? (Or point to a ressource I could read on it?)
(Sorry if this has been covered many times.)
Edit:
Found this => http://www.generalguitargadgets.com/how ... istortion/ and especially this part :
A non-inverting preamp is a circuit where the input is connected to the non-inverting (+) input of the opamp and feedback loop is between the inverted input (-) and the output.
Non-inverting preamp
The gain of a non-inverting opamp is set with resistors R1 and R2. The gain equals (R1 + R2)/R2. Values of a few kilo-ohms will be a good choice. A specialty of the non-inverting opamp is C1. That capacitor along with R2 form a low-pass filter (explained later). A disadvantage using non-inverting opamps is that they can’t have a gain less than 1, meaning that they can’t attenuate the signal, but as this is useless in distortion effects, we can discard that.
I assume this is what this gain stage is, so I understand why raising R3 to 2k2 would induce less gain, I might try to bump it to 4.7k to lower it even more. (Should I raise R4 then?)
However, I'm still confused regarding C2, why did you lower it? (Or was it related to the tone issue?)
tete1805
Post by tete1805 »
So, I've read a bit about overdrive circuits and here's what I came up with:
The duo C2/R3 act as a high pass filter (or low shelf), so you can't change one without adjusting the other.
MoonWatcher advised a 2k/150n pair, this would raise the cut-off from 480hz to 530hz. (A little bit less low-end, so more perceived mids but not very hearable.)
I didn't mind something a bit more transparent, so I used a 2.4k/200n pair, which lowered the cut-off frequency from 480hz to 330hz. (A little more low-end, so a little less mids.)
It actually works pretty good.
R4 controls the minimum amount of gain, so I lowered it to 2.4k as well, to match R3.
Gain now starts at around 1/1, so a lot less then 10/1 initially, or 5/1 after the first modification.
The gain pot is now pretty low gain on the first half, but will still be fairly high gain on the other half.
To be noted, the trio C3/R4/Gain pot act as a low pass filter (or high shelf) so modifying R4 changed a bit the frequency, but as it's mostly controlled by the gain pot value, it didn't change anything that I can really hear.
I assume this is to tame a bit of high frequencies on high gain settings.
The trio C4/R7/Tone pot act as another low pass filter (or high shelf), per MoonWatcher recommendation, I lowered R7 to 2k, but I think it's the wrong approach as it doesn't really change the course of the tone pot.
It added a lot of high end when the pot is maxed-out, but it's quickly overridden by the tone pot value.
I'll try to replace C4 with a 3n3 cap and R7 with a 5.1k instead.
This will tame the tone control a bit more.
Initial values give a range of 440hz to 2.65khz.
The initial resistor swap gave a range of 510hz to 13.2 khz, but dropped fairly fast. (Only the top part of the tone pot is usable and the range is really narrow.)
The cap swap plus the new resistor will give a range of 875hz to 9.46khz.
This should make the tone pot more usable on the full course.
Feel free to add to the conversation if I missed something or if I made a wrong assumption.
All values are calculated using the fantastic http://www.learningaboutelectronics.com ... ulator.php and http://www.learningaboutelectronics.com ... ulator.php.
