Freakshow Effects Boost Schematic tracing?
Hey guys. My cousin gave me his broken Freakshow Boost and asked me to fix it. I can't find a schematic anywhere, and I don't really know how to trace a PCB. It only has a handful of components. Just wondering if anyone would be willing to trace it for me? You'd need photos of both sides of the board, right? As a perk, others will be able to build it, since I think Freakshow stopped building. My cousin said it was the best sounding boost he'd ever played before it bit the dust.
- roseblood11
Photos of both sides of the pcb. Maybe some shots against a bright light, so that you can see the connections through the board. And you should write the parts list, as it's hard to read the values and colour codes from photos.
If you're in bright daylight, a smartphone camera is a very good tool for close-up photos
Here are some pics. I took a bunch of angles since it's hard to see around the switch.
- Nocentelli
- Has thanked: 1152 times
- Been thanked: 954 times
Something like this?
Thank you for drawing this up! I didn't want to ignore your post but I've got a busy few days coming up. Hopefully I'll have a chance to look at this in depth over the weekend.Nocentelli wrote:Something like this?
[EDIT]: Oh, so it's an LPB-1...
- Manfred
- Has thanked: 1672 times
- Been thanked: 1344 times
Rather, like this circuit pattern:Oh, so it's an LPB-1...
Ah good catch. It looks like the difference from an LPB-1 is the 511k resistor (in this case) going to the collector, versus to V+. It's amazing how many pedals are Jack Orman's circuits with a few value swaps.
