Boss - TR-2 Tremolo - V2 with That2181 VCA [schematic]
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
Throwing this one out there to see if anyone can help supply the missing component values - cannot believe that this schematic is nowhere to be found on the internet - I have modified the first edition schematic but need some help to finish the schematic.
If you can help it would be good.
- bajaman
I need component values for R46, R47, R54 (and the parallel capacitor number and value), C22, and D9
- george giblet
- bajaman
Thank you George
Here is the updated preliminary schematic with your amendments added.
Still not sure about that D9 diode The best board picture I have seen it is clear glass with a blue band.
- aion
Clear glass with a blue band are usually the Japanese 1N914/4148 equivalents, right? 1S1588 or similar? I see them on Maxon and Ibanez boards too.bajaman wrote:Still not sure about that D9 diode The best board picture I have seen it is clear glass with a blue band.
- karul
- original-TS-1S1588.jpg (54.55 KiB) Viewed 5124 times
- 1S1588-1.jpg (31.97 KiB) Viewed 5124 times
- 1S1588-2.jpg (37.38 KiB) Viewed 5124 times
- bajaman
Thanks for that aionios and karul
It is great news getting all this help to finalize the schematic
here is the latest schematic update
- george giblet
FWIW, the diodes I saw had a smaller package DO-34 (MHD), like these,
The part numbers for blue diodes were,
1SS119, 1SS120, 1SS270
The 1SS120 has a marking "1",
https://w.atwiki.jp/mcmaster/pages/356.html
The pic I saw of the TR-2 had a marking "2" but I can't find any diodes with marking.
- bajaman
Yes George - the pictures I have seen do show a diode like that - short and stubby - could it be a zener perhaps ?
I checked the datasheets and the only diode with a mark on it was the 1SS120 (1)
Thanks for the info - we are not there yet
- bajaman
here is the best picture I have found showing the D9 diode - the board marking does not suggest a zener - perhaps the 1S120 will work
- george giblet
In one pic I saw a black diode with a number on it. The package looked a bit more like the 1N4148 etc.Thanks for the info - we are not there yet
I can at least confirm C27 *is* 47n.
- bajaman
updated schematic with confirmed C47
Thanks George
Thanks George
- aion
I've got one of these incoming, so next week I can confirm anything else you need and take any necessary measurements (diode forward voltage, for instance). We'll get this one conquered!
- george giblet
Be cool if you could check the value of C29 too.I've got one of these incoming, so next week
I haven't been able to narrow the diode down. The only diode I saw with a "2" marking was a green one.
- Manfred
- Has thanked: 1675 times
- Been thanked: 1360 times
IMO D9 could be any small signal diode, because IC3b works as an inverting amplifier where its amplification gain is depending on the signal polarty,
switched by the diode.
- george giblet
You would think so. What I find odd, which also make me a little suspicious, is they are already using the yellow band 1SS133 diodes so why use a different diode in that one position?IMO D9 could be any small signal diode, because IC3b works as an inverting amplifier where its amplification gain is depending on the signal polarty,
- Manfred
The only difference between the both diodes is the maximum reverse voltage, the other data are the same.
The maximum reverse voltage of the 1SS270 is 35 Volts, of the 1SS270A is 70 Volts,
but without relevance for a 9 Volts power supply application.
My guess is that BOSS used both one for the same applications depends on its availability.
- Manfred
Sorry, you talked about the 1SS133 diode.you would think so. What I find odd, which also make me a little suspicious, is they are already using the yellow band 1SS133 diodes so why use a different diode in that one position?
The the junction capacitaces and the reverse recovery times differ a very ittle from the 1SS270x diodes.
These values in the Pikofard and Nanosecondes range are without relevance for this application too.
The threshold voltage is 0.1 Volts higher than the those of the 1SS270x diodes.
As mentioned above, any small signal diode should work for this application.
