Darkglass - Microtubes B3K / B7K [traced]
- Manfred
- Has thanked: 1675 times
- Been thanked: 1360 times
Sorry, Deltafred you are right and I must apologize you have written of non-buffered but not of non-inverting.
Thanks also to Jim to point this out.
I don't know why I misinterpreted that from the context.
- Manfred
I retraced my train of thought again and found out why I was wrong.
I considered the buffer to be inverting and made the conclusion, that by omitting it out, the inverting behaviour of the 4049 stage is lost.
This was wrong because the buffer is non-inverting.
Now I know what you meant, adding the buffer provides more gain and low output resistance of the 4049 inverter stage.
So this stage with the high input resistance, the high gain and the low output resistance behaves like an OP-amp as an inverting amplifier.
Therefore only the buffered version of the 4049 is usable for analog applications.
- deltafred
- Opamp Operator
I think you mean un-buffered.
I'm glad we've got that sorted out. The internet is not really the best platform for technical discussions.
Anyway my question still stands. Were those builders who were having problems with "crackling" using a 4049 or a 4049UBE? If any of them are reading this thread I'd be very interested.
- Manfred
Yes, you're right, I did twist it again.deltafred wrote: ↑01 Oct 2020, 10:10I think you mean un-buffered.
I see in the buffered version there is an internal buffer at the input and the other one at the output.
Since both buffers are inverted, the signal remains non-inverting.
The transfer curve is very steep with a hard transition at the ends.
In the unbuffered version, the slope is noticeably flatter and the corners are rounded, making it suitable for analog applications.
I can imagine that the buffered version produces an unpleasant fuzz sound, because the input signal causes a fast flip of the output and so a steep square wave signal appears at the output.
I think now I have understood it.
- Manfred
To avoid further misunderstandings I add that the function of the unbuffered version is maintained.I see in the buffered version there is an internal buffer at the input and the other one at the output.
I have both 4049 and 4049ube - will be at home soon (10-12 days) and check both in my pcb.deltafred wrote: ↑01 Oct 2020, 10:10I think you mean un-buffered.
