K&K - Pure XLR Preamp  [traced]
Bononoob
Been thanked: 68 times
Post by Bononoob »
I have this Preamp because someone wants me to modify it. So I traced it
K&K makes preamps and mics for acoustic guitars, it's a nice and simple design if you're looking for something like this.
Here's the Eagle Schematic and some gutshots. Tell me if I made mistakes!
edit: Changed C14 polarity
Science is art. Art is science.
https://electric-canary.com
lukatosh
Has thanked: 33 times
Been thanked: 186 times
Post by lukatosh »
Hello, thanks so much!! Just one question, the 22uF capacitores are non-polarized?
marshmellow
Has thanked: 20 times
Been thanked: 127 times
Post by marshmellow »
Are you sure about R20/R21? I would rather expect 4,7k, 47k, ... There isn't much to point to having an additional pad at the output with a volume control that goes to zero anyway. It only makes it harder for the 4558 to drive such a low load. I don't know if this is meant to plug into a microphone input or a line input, but the reality is many budget mixers or recording interfaces don't always feature line inputs. So with a low impedance microphone input of 1-2k connected, the load gets even worse.
Bononoob
Post by Bononoob »
lukatosh wrote: 28 Jun 2020, 03:59 Hello, thanks so much!! Just one question, the 22uF capacitores are non-polarized?
Hey, no probs! No, all 22µF are polarized and oriented like in the schematic.
marshmellow wrote: 28 Jun 2020, 10:51 Are you sure about R20/R21? I would rather expect 4,7k, 47k, ... There isn't much to point to having an additional pad at the output with a volume control that goes to zero anyway. It only makes it harder for the 4558 to drive such a low load. I don't know if this is meant to plug into a microphone input or a line input, but the reality is many budget mixers or recording interfaces don't always feature line inputs. So with a low impedance microphone input of 1-2k connected, the load gets even worse.
Yes I'm sure. I checked again they are SMD marked 471. I don't think R20/R21 are pads, the preamp can be powered by phantom power. Maybe you thought V+ was ground? Anyway thanks for checking it out!
marshmellow
You're right, I completely overlooked the phantom powering :slap:.
Bononoob
Post by Bononoob »
edit: phase switch is now correctly oriented
skizoide
Been thanked: 16 times
Post by skizoide »
Hi.
So, all the V+ (+48v) must be connected?
