Complete Maestro Service Manual, indexed PDF
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
A very nice guy called Joe Palermo was going through some stuff and found this. He decided to donate the high quality pictures he took to a facebook group. I downloaded the pics and compiled it into an indexed PDF.
Here is a handy, perfectly readable lores version of this file. I need so sort some serverstuff out, then I will be able to host the higher quality versions I have. Done.
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
fantastic - thanks so much
- Dirk_Hendrik
- soulsonic
Weird mistake in the FZ-1S schematic. Line drawn wrong shows output of fuzz connecting to R5 instead of R7, and R7 is connected to 9v. It seems the connections of R5 and R7 are swapped from what they should be. Is this already a known issue with the factory schematic?
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 281 times
Nice crowd here.....
Thanks for posting Johan!
Greetings,
Fantastic, thanks so much! Didn't know they made so much FX stuff, plenty of projects in there.........
Regards, Jim
Regards, Jim
- george giblet
The evince PDF viewer I have actually shows an Archive Type not supported error.
- modman
- a d m i n
Thanks for the heads up -george giblet wrote: ↑22 Oct 2021, 21:09 The evince PDF viewer I have actually shows an Archive Type not supported error.
You are using Linux?
Does this mean you are unable to access the file at all?
If you open the application first, then access the pdf, do you still get the error? https://gitlab.gnome.org/GNOME/evince/-/issues/1506
Do you have the same problems with other pdfs?
J
- george giblet
Yes I'm using Linux, I tried opening the first two files with no success.Thanks for the heads up -
Your trick of opening the file directly worked.
The way I've got the browser set-up is it never view files *in* the browser, it always has the pop-up to open or save. If I choose opens it open the pdf in the Evince viewer as an external program with its own window.
Here's the results of the different opening methods:
- Opening via the link - doesn't work.
- Double clicking the file in the Firefox downloaded files list - works. (I thought I did that yesterday)
- Saving the file then open the file directly in the "Files" file manager - works.
Funny thing is I haven't seen that problem before. I must have about 5000 PDFs on my machine.
It's likely not all were viewed via the browser.
- george giblet
You wouldn't believe it, I had another instance of this on a datasheet today.
george giblet wrote: ↑26 Oct 2021, 22:03 You wouldn't believe it, I had another instance of this on a datasheet today.
Yeah, I'm on a Gnome based Linux, and the built-in pdf viewer can get wonky. I use Firefox to view them when this happens. Seems like a kludge, but it works fine.
- george giblet
I did a few updates on my system (Firefox 88.0 and Evince 3.18.2) and now it works.Yeah, I'm on a Gnome based Linux, and the built-in pdf viewer can get wonky. I use Firefox to view them when this happens. Seems like a kludge, but it works fine.
I've been putting off updates for some time. The updater was failing because of Libreoffice and Wine. I had to manually set-up some new repository locations and import new ppa keys. The Ubuntu updater often screws up when the OS version falls down the list - total PITA.
