- Practical-Electronics-1976-01 Audio Compressor.pdf
- (455.8 KiB) Downloaded 101 times
S. Whitt, Audio Compressor, in: Practical Electronics, January 1976 🇬🇧
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
PDF:
- mictester
Basically, it varies the working point of the transistor by moving its bias, thereby varying its gain. This was an approach used in some communications receivers in the 60's as a crude "audio AGC". It tends to introduce lots of distortion (it'll be a slightly squeezed fuzz sound), which doesn't matter too much in a communications receiver, but is simply NOT hi-fi enough for most purposes.
Other - slightly unusual - approaches to gain changing stages I've experimented with include using a "diode attenuator", where the current through a couple of diodes varies their dynamic impedance. This works well, and as long as your audio is only a few tens of millivolts, it works without significant distortion.
Other approaches include using ordinary bipolar transistors as voltage-controlled attenuators, using LDRs (as in the Really Cheap Compressor), using transconductance amplifiers (as in the Dynacomp), and using transconductance amps in the negative feedback loop of op-amps (my favourite method).
If you try the above circuit, don't be surprised if you get LOTS of distortion and noise!
