Digital reverb engine AL3201
- KMG
Plug in module
Schematics (pdf)
Ready to transfer PCB (pdf)
Upper side assembly (pdf)
Bottom side assembly (pdf)
Minimal connections
Board with input and output levels adjusting ±15 dB and dry/effect mix
Schematics (pdf)
In case (not finished yet - no markings) with UV meter and digital effect selector
To the digital connector it is possible to connect micro-controller for loading your own programs in DSP.
Example of program for ATMEGA128, compatible with Wavefront DRE Development System.
http://milas.spb.ru/~kmg/files/projects/dre/avr/
Example delay with digital feedback (5 DSP commands)
Maximum possible delay (mono) 30% feedback
http://milas.spb.ru/~kmg/files/projects ... /1/03M.mp3
Intermediate delay 50% feedback
http://milas.spb.ru/~kmg/files/projects ... s/1/05.mp3
Intermediate delay 70% feedback
http://milas.spb.ru/~kmg/files/projects ... s/1/07.mp3
Intermediate delay 90% feedback
http://milas.spb.ru/~kmg/files/projects ... s/1/09.mp3
Project page
http://milas.spb.ru/~kmg/dre_en.html
Schematics (pdf)
Minimal connections
Schematics (pdf)
Project page
- bajaman
- Has thanked: 593 times
- Been thanked: 2049 times
very nice Mike - thanks for sharing here
- KMG
Link to manufacturer site Wavefront Semiconductor. Datasheet, software examples. development system.
http://www.wavefrontsemi.com/index.php?products
Analog: COOLAUDIO CV1000
http://www.coolaudio.com/products.html
China clone
http://www.bdnc.com/datasheet/bd3201-14A_spec_V1.6.pdf
China clone
- Greenmachine
- my favorite amplifier: Fender Blackface Deluxe Reverb
- Completed builds: Electra Distortion
Roger Mayer Octavia
Klon Centaur (Bajaman/Soulsonic)
DOD 440 Envelope Filter
MXR Phase 90
DOD FET Preamp
Dallas Arbiter Fuzz Face
Soulsonic Hunny Bunny Overdrive
BYOC Analog Delay
Craig Anderton Headphone Amp
Anderton Mini Amp
Bajaman Real Tube Overdrive
Fender Deluxe 5E3 with Tone Stack Mod.
Fender Princeton 5F2-a
Keen Neovibe
Aquapuss Delay
Anderton AMS-100 Guitar Synth (abandoned)
DOD 280 Compressor
Weird Sound Generator
Beavis Audio Noisy Cricket
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Really Cheap Compressor - Location: Jersey City, NJ
- Has thanked: 87 times
- Been thanked: 17 times
- Contact:
You are like Zorro, or Batman or something.
When I read your project files I feel like I'm eating dinner at the kiddie table wondering what the adults are talking about.
Yeesh.
Yeesh.
"[Y]ou want sketchy, dude? I breadboard on a door." -- RnFR, 2011
"This amp is freakin loud, like crazy, I'm going to kill pets loud." -- mich, 2011
- KMG
As the experiment I tried to make the imitation of analog delay.
ATMEGA measures the position of potentiometers (through ADC) and dynamically changes DSP program: delay factor and feedback depth.
This chip allows to load from 1 instruction to whole program buffer. So for this imitation I have to modify only two instructions (this takes very short time). Full illusion of analog delay.
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 70 times
- Been thanked: 66 times
- Contact:
The CoolAudio V1000 (copy of the AL3201), an audio codec and an Atmel microcontroller are available for cheap in most digital Behringer pedals : DD-600, DR-600, FX-100, etc. (not the "machine" ones, they use a bigger DSP).
The easiest mod would be to disconnect the controller, and use 4 switches to select one of the 16 presets. The more complicated mod would involve custom programming of the DSP, thru custom programming of the controller.
I still have to dump the I²C messages between the controller and the DSP on my DD-600, before trying to re-program them ...
but i've been playing more with my guitar than my soldering iron lately
- KMG
Unfortunately the protocol of the exchange there not I²C but its unique, read datasheet carefully.
There is source of exchange protocol with AL3201/V1000
http://milas.spb.ru/~kmg/files/projects/dre/avr/Dre.c
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Contact:
Ooops, maybe that's why i had problems with the I²C sniffing ...
must. read. datasheet. carefully.
And thanks for the source code !
I'll port that on Arduino when i find some time.
- rocklander
- Has thanked: 1406 times
- Been thanked: 231 times
- Contact:
shame the links have gone astray.. I'd be interested in seeing more applications of the v1000 chip... any reason it appears to be passed over?
- KMG
Wait several days, process of moving domain name to new IP address.
Immediately you can get information by changing domain name in links to IP address.
http://217.119.30.118/~kmg/
- Dirk_Hendrik
Never seen this thread before. Even without those file I think KMG is going to be on my cool list for the next couple of weeks.
- andre
- my favorite amplifier: Hughes & Kettner Statesman Quad
- Completed builds: Dist + overdr.: Distortion+, BSIABII, Shaka III, Bluesbreaker, Box of Rock, Highway 89, DS-1, Proce Rat, Omnidrive, TS808, Bluemagic, Fulldrive 2, big muff
Delay: DM-2, Rebote 2.5, PT-80
Modulation: Ross Phaser, Small Clone, CE-2, Zombie chorus, FL-301, Easyvibe, Ultraflanger
Compr.: Dod280, Dynacomp
the rest: SG-1, Sparkleboost, BAJA CX-3 leslie simulator - Location: Netherlands
- Been thanked: 6 times
FYI here's a little demonstration of my Femtoverb, a AL3201 based circuit, for which I build a controller with an LCD display and some buttons.
The demo shows all of the factory presets.
There is some reverb audible even in the non reverb presets because I forgot to turn of my amps reverb, but still the demo will give a good impression of the AL3201's presets
- Dirk_Hendrik
I was looking how to replace the internal AL3201 programs and came upon this thread. So my question is are there any free FX files available for this chip (interested mostly in delays) and a guide how to load them into the chip?
