Boss OD-1B no sound
- CheapPedalCollector
Yep the chip is bad.
I found one on ebay for around $20. Let's hope it's the real deal!
Got the new chip in and I have the same results. I've checked all resistors and diodes and all are good. Maybe a cap?
- mauman
Maybe C7 is shorted? Sounds like something connected to that IC pin 7 pulling it down, maybe the OD pot or the wiring to it. Gotta be close by if you have no sound at all on pin 7. Does turning the OD pot change it? If so, it may be something closer to pin 6, maybe as far away as C5, but if so I think you'd hear at least something on pin 7.
- Manfred
- Has thanked: 1675 times
- Been thanked: 1360 times
Unsolder the gain potentiometer and connect pins 2 and 3 of the board.
Then you got minimum gain, and the potentiometer as a source of error excluded.
Actually signal should come out then.
Measure in advance with the ohmmeter pin7 with respect to ground to make sure that there is no short circuit.
Pin 5 - 3.85V
Pin 6 - .076V
Pin 7 - .006V
Pin 6 - .076V
Pin 7 - .006V
Bypassed the pot and now I have sound on Pin 7 and the pedal works!
- Manfred
I suppose that there is a faulty connection to the potetiometer.SuperHorndog wrote: ↑05 Apr 2022, 00:30 Bypassed the pot and now I have sound on Pin 7 and the pedal works!
Redid the wiring to the pot and all is good.
- Manfred
Did you also check the potentiometer function with an ohmmeter?
