SolidGoldFX Super Drive [schematic]
Wish you all the best...in this damn Covid-19 pandemic
This is SolidGoldFX's Super Drive pedal
dismantling...
Top Down
The Schematic
PCB
Circuit board proofing file...
dismantling...
Top Down
The Schematic
PCB
- FuzzMonkey
Cool. Thanks.
- Ichabod_Crane
Thanks.
How the Volume pot could work wired like that?
And is the 560 cap a 560pF? I found it very big.
Ichabod_Crane wrote: ↑24 Apr 2022, 15:06 Thanks.
yes, 560pf
Volume pot... hmmm, yes, there's a bug (corrected now
- Ichabod_Crane
Thanks.
Though, I expect a sound too much dull with a 560pF in the feedback loop, I guessed it was a 56pF, but if it was a small cap it would probably a ceramic cap. (The DOD250 and the MXR Distortion+ have no cap or just 10-25pf cap or so). From the demos I saw this pedal sounds a bit shrill.
Are you really sure that cap is right in the feedback loop? Sometime hard clipping pedals are a caps like that in parallel with the diodes.
Anyway, I didn't try the circuit, maybe you did?
I'm sorry for my insistence.
- FiveseveN
Capacitor code 560 means 56 pF: 56 * 10^0, which gives a more reasonable cutoff at about 3 KHz.
In other news, holy output impedance, Batman! Couldn't find the cash for them fancy dual op-amps?
- ppluis0
Actually, 101 and 560 capacitors are not present on this board, but they were present in some early versions,Ichabod_Crane wrote: ↑25 Apr 2022, 08:21 Thanks.
(sorry,I made a spelling mistake,560 is 56pf,Thank you for correcting me) C10 is a 101 capacitor,C11 is a 560 capacitor
- bmxguitarsbmx
True that. And that high impedance makes for a very dependant (on volume setting) presence control. If the order was reversed, and the signal hit the presence circuit before the output volume circuit, the presence would be much more consistent in operation. (Shelf sweeps a wide range depending on volume setting).
- Ichabod_Crane
That still makes me perplexed, indeed.
I'm thinking about to build something similar to this pedal, but probably I'll reverse the two pot.
Maybe I'll try it on my breadboard. But I don't know when, don't waiting for me!
