Woolly "James" Mammoth
- ~arph
I'm building some mammoths, with improved tonestacks.
Here's the schematic I'll be using. Kudo's to the creator of the James stack. I don't know who it is, but I think I first saw it in the James Muff and the SFT. It must go way back though..
The output buffer is also from the James muff.
Merry christmas!
Merry christmas!
- james-mammoth.png (10.91 KiB) Viewed 3832 times
- soggybag
- Completed builds: Fuzz Face, Tone Bender, Big Muff, ICBM, Ugly Face, Green Ringer, Super Fuzz, Multiplex Echo, Multiplex Jr, Rebote, Echo Base, SHO, Fuzz Factory, Titan Boost/Octave, Easy Face, Tone Bender MkII, Trem Shifter, Zero Point Mini...
- Has thanked: 28 times
- Been thanked: 27 times
- Contact:
Great idea, I had just been planning a Woolly Mammoth with a BMP tone control.
I'm guessing that R5,6 is a pot and R9 and R10 is another pot.
Blog: http://super-freq.com
- oldgravity
The James is the passive version of the Baxandall tone control - I believe it's so named because Peter J. Baxandall's middle name was James. So this would be from the 1950s.~arph wrote:Here's the schematic I'll be using. Kudo's to the creator of the James stack. I don't know who it is, it must go way back though..
Here's the original paper:
http://home.comcast.net/~stphkeri/Negat ... ckTone.pdf
- ~arph
Yes R5,6 and R9,10 are pots
also note that the "Wool" control is missing from the schematic. There should be a 2kB pot between the negative side of C3 and GND
Plus to tame the noise I got when built, I placed a 220pF between the base and collector of Q1
- oldgravity
Nope, I was wrong. The James is by E.J. James, and here's his original article:oldgravity wrote: The James is the passive version of the Baxandall tone control - I believe it's so named because Peter J. Baxandall's middle name was James. So this would be from the 1950s.
http://home.comcast.net/~stphkeri/James ... ontrol.pdf
So the James tone stack actually dates to the 1940s!
- ~arph
Ha,
And that document has a correspondence in it that says it was designed by Michael Volkoff in July 1939
So perhaps it should be the Volkoff tonestack then..
- soggybag
- Contact:
What should the pot values be for R5,6 and R9,10? Looks like you have two 1M resistors for R5,6 and two 500K resistors for R9,10.
- ~arph
Well, it's the james tonestack from the 21st century big muff.
Bass 1M lin, and treble 500k Lin or 1M lin. Both work fine.
It looks a bit funny since the schem is from LTSpice. I was simulating the circuit and decided to throw it out here as I had it drawn up already. That is also why the wool pot is missing. I have it at max gain here.
I was simulating the tone control settings, that is why you see no pots there but two resistors with a parameterized value.
One resistor has value {1meg * param}, the other {1meg - 1meg * param} If we step the param between .1 and .9 then the first resistor will go from 100k up to 900k and the latter from 900k to 100k, hence simulating a rotating pot. The point these two resistors connect is the wiper.
When I built it, it was too noisy with the wool maxed out, so I added the 220pF
- soggybag
- Contact:
I have this in the breadboard right now! I put it together a couple days ago. I hadn’t seen this post until just now!
