Help converting 2P3T slide switch to DPDT toggle
Eightsevenzero
Post by Eightsevenzero »
Complicated switch wiring always throws me for a loop for some reason so I'm hoping you guys could help me out. I have a 10 pin 2P3T slide switch that I would like to replace with a DPDT toggle. Using the schematic attached, how would I go about wiring the DPDT to the same effect? I copied this connection info from another thread:
Pins 1 and 5 connect to the same plane, as do pins 6 and 10.
The two sliding switch contacts move in tandem.
Contact 1 connects pins 1&5 to either 2, 3 or 4.
Contact 2 connects pins 6&10 to either 9, 8 or 7.
When 1&5 are connected to 2, 6&10 are connected to 7.
1&5 to 3 means 6&10 to 8.
1&5 to 4 connects 6&10 to 9.
Nocentelli
Has thanked: 1155 times
Been thanked: 954 times
Post by Nocentelli »
Eightsevenzero wrote: 15 Aug 2022, 02:06
Contact 1 connects pins 1&5 to 2, 3 or 4.
Your switch needs a minimum of three throws, i.e. three possible positions. A DPDT is a "double pole double throw" so cannot be used since it does not have enough throws. You can get rotary switches that can be used to replicate the 2p3T action of your slider switch, though.
Eightsevenzero
I figured this as well but it's actually been done with a DPDT:
https://images.reverb.com/image/upload/ ... uybvii.jpg
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 207 times
Post by grrrunge »
If it's the "range" toggle you're looking at, it looks like it's been done with an on/off/on toggle switch. Let's see the entire schematic, so we're not going into too much guesswork here :)
Eightsevenzero
Yep, the range control.
grrrunge
Post by grrrunge »
Uploaded to avoid the usual image hosting troubles down the line... :horsey:
Ibanez DE7 schematic
Are you building a clone, or are you rehousing an original?
